need loud and low.. size doesn't matter - Page 2 - diyAudio
Old 24th February 2010, 03:25 PM   #11
justint is offline justint  United States
jbell just to clarify from your chart what is the 1 cabinet you are refering to that is marked in grey?? per your chart
Old 24th February 2010, 03:45 PM   #12
djk is offline djk
djk's Avatar
A dual 15 corner horn using the CSS SDX15, and XBL^2 driver with 30mm (one way) x-max.
http://www.creativesound.ca/pdf/CSS-...ata-121107.pdf
The design is thermally limited (according to Hornresp), but could handle 6dB peaks within x-max limits above 35hz or so (worst case is 17.5mm at 1.8KW at 35hz, a null at 40hz, and a peak of 12.9mm at 55hz).
If built with a bifurcated path, each mouth would only need be 3200 cm^2 (about 100cm tall by 32cm wide, or 39.4" x 12.6"). Suggested layout would be like the later JBL Hartsfield or Klipsch Jubilee.
Candidates for the Darwin Award should not read this author.
Old 24th February 2010, 04:02 PM   #13
jbell is offline jbell  United States
jbell's set of four tapped horns
it's my big cabinet I used for my football stadium install.
Old 24th February 2010, 05:18 PM   #14
expert in tautology
bear's Avatar
I thought you guys said "sub-woofers"?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th February 2010, 10:00 PM   #15
djk is offline djk
djk's Avatar
This isn't home theater.
In the context of PA, if it has good output below 60hz it's a subwoofer.
Looking at actual dance music program material content, I see very, very (very) little below 40hz.
Does size really matter - SE Output wicked1 Tubes / Valves 19 13th March 2008 06:25 AM
bass matrix hole size....does it matter i4gotmyid Multi-Way 1 5th October 2007 04:27 PM
Does physical size matter still4given Power Supplies 4 25th November 2004 09:26 AM
Does Size Matter sirius98 Multi-Way 11 10th November 2004 04:27 AM
Size does matter.. dutch diy Multi-Way 3 19th July 2001 10:30 PM
Copyright 1999-2017 diyAudio
