Hi there,
A friend of mine has a Velodyne sub which has developed a problem. Opening it up it appears that one of the components on the servo is fried and has started oozing: He called Velodyne but they want to sell him a new board for over $500. Seems to me that component is likely the problem and I'd just replace it if I knew what it was. The text on the side is "917Td701". The sub is a model HGS12BGE from 1999. Thanks in advance for any clues |
#2 |
That appears to be a small cermet trimpot. These do not contain electrolytes or anything that could leak.The black/browning material could actually just be epoxy to prevent the trimpot from rotating. Are you sure this part is actually fried/the culprit?
#3 |
Thanks db! My friend confirmed it has 3 pins so that would figure. Back to the drawing board..
#4 |
Check the piezo element that's located in the cone. There should be a couple extra wires (probably from that board) going to it. The piezo is used as a stress pickup to determine acceleration for the servo control logic. For me, I've seen many dead ones.
Consider returning it to the company if they offer a repair service, as it will require alignment after replacing, if it's even possible to get in there without damaging the dustcap. Good luck. How to test it, I don't know. Try here as a stating place: Piezoelectricity - Wikipedia, the free encyclopedia
Think out of the box
| any use for velodyne plate amps? | cowanrg | Solid State | 60 | 12th May 2011 10:11 PM |
| velodyne f 1500 help | daran | Subwoofers | 0 | 30th December 2007 10:53 AM |
| velodyne sub problem | steven344 | Subwoofers | 2 | 22nd May 2006 06:26 AM |
| Velodyne T/S measurements | logonwheeler | Subwoofers | 0 | 18th December 2005 07:07 AM |
| entry level velodyne | RockysDad | Subwoofers | 3 | 18th December 2005 06:04 AM |
| Page generated in 0.06933 seconds (77.79% PHP - 22.21% MySQL) with 10 queries |
