Old 16th February 2010, 08:10 AM   #1
Boscoe is offline Boscoe  United Kingdom
Default I need an 8" Sub
I need an 8" sub woofer driver, it doesn't have to look that good as it won't be on display, I would like a reasonable output around 150Wrms and, if possible, to be on a low budget. Thanks
Old 16th February 2010, 08:17 AM   #2
frugal-phile(tm)
planet10's Avatar
Ones to consider are the CSS Trio 8 (i have 4 i'm playing with), Wavecor has a nice one that fots in a very small box, there is a Tangband that is polular and the Apex Super 8 os a value leader (i have a push push sub with these drivers)
I'm sure you will get more suggestions.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th February 2010, 09:34 AM   #3
chris661's Avatar
The one I'm using is £16. DVC, 60W per coil.
--|55-1455|DUAL COIL WOOFER 8" | CPC
If you're interested, I'll send you a copy of the PDF with all the parameters in.
It prefers ported over sealed, will hit mid 30s in a 30L box tuned to around 40Hz (maybe lower)
I put two of them in a 42L sealed box, Linkwitzed them to death and got 28Hz f3.
You say the drivers won't be shown. What enclosure are you thinking of?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
31 Band Equalizer "the t.eq" "TQ-60" schematic wanted tiefbassuebertr Solid State 2 29th March 2010 03:45 PM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout tcpip Solid State 126 15th February 2007 04:50 PM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.05718 seconds (79.36% PHP - 20.64% MySQL) with 10 queries
