Need help guys...want to make a horn box - Page 3 - diyAudio
Old 12th February 2010, 04:58 PM   #21
pat allen's Avatar
Originally Posted by GM View Post
OK, but did it use this driver?
Regardless, reducing the rear chamber's Vb and adding a straight initial expansion increases its HF gain BW above 100 Hz at the expense of some acoustic efficiency with the length and flare frequency governing the shape of its pass-band response. Unfortunately, adding another section means the Loudspeaker Wizard is disabled, so you'll have to do it the old way of tediously comparing different input values instead of seeing it in real time as you use its sliders.
Anyway, using your dims and adding a 20" long flared section expanding to ~116.25"^2 (750 cm^2) yields a ~maximally flat half space response of ~23.7 Hz -185 Hz. Again though, the simple ducted port alignment I suggested yields more bang/buck and easier to build, but being more acoustically efficient it's ~50% bigger also, though still tiny by my standards for a 'sub'.
Note that published specs are probably off enough to render all this moot unless significant EQ is used.
GM
thanks for thoses details. The sub has been given to me (free), and i realise it is not a well suited sub for the task, altough it plays well enough in a car.
I may look for a better sub (Dayton's ?).
I am realy considering the Tuba HT for now. I have plenty of amps for the task (CAS II 1200w and a BGW 7000 proline 650w) so i may overpower the sub anyway
Electronic engineer for automotive market.
Old 13th February 2010, 01:17 AM   #22
GM is offline GM  United States
GM's Avatar
You're welcome!
OK, then since it won't cost much in materials/labor, why not build one of these designs to see if it satisfies you and report back?
WRT the tuba's power handling, below its horn gain BW it's just a sealed alignment, so up to the point where the VC overheats, it's self protecting.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th February 2010, 03:44 PM   #23
pat allen's Avatar
You're welcome!
GM
i bought the plans already. i may start building that next week. i will report for sure here first, theirs forum is invaded with knows-it-all newbs that pretends themsevles knowledgeable or "expert"...
Its time one of you guys make some money! dcfis Class D 35 10th April 2006 10:51 PM
guys , plz remind me how to make a comparator :) sss Solid State 2 7th November 2005 04:54 AM
help me to make my own box tobler Multi-Way 1 3rd July 2005 04:13 PM
Box Design/Make me a Box Focal 5WS arnach Car Audio 5 13th December 2004 06:56 AM
All you horn guys and gals Variac Multi-Way 6 17th June 2003 08:27 PM
Copyright 1999-2017 diyAudio
