TH path length opinion needed
Old 9th February 2010, 01:42 AM   #1
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Default TH path length opinion needed
I got stuck, I don't see a correct way to calculate L34 and S3
TIA
Dan
Old 9th February 2010, 04:02 AM   #2
FlipC is offline FlipC  United States
Well we know S3 goes from the middle of the driver (rear side) to the closest reflection. Which in this single fold will be a distance. While L23 will be where it connects to L34.
Less I am wrong which I think someone will chime in.
Old 9th February 2010, 06:21 AM   #3
NEO Dan's Avatar
That's interesting. IMO if it has to be based on the drivers axis this would be more like a single fold:
Click the image to open in full size.___Click the image to open in full size.
28.28v / 100w
Dan
Old 10th February 2010, 02:10 AM   #4
tb46 is offline tb46  United States
Default Tapped Horn Path Length
Hi NEO Dan and FlipC,
This looks interesting. I like to use the four section version, and asign an average value to S4 (=S3+S5)/2 (as it cannot be determined accurately). S3 and the distance S2 to S3 can be determined accurately. From the drawing you can see how I asign S3 to S4, and S4 to S5 (approximating the center of the cone as S4 location). I feel this method gets you in the ballpark.
Oliver
Old 10th February 2010, 07:00 AM   #5
NEO Dan's Avatar
Oliver,
Thanks for this, I'll update the model when the drivers come in.
Dan
Old 10th February 2010, 02:27 PM   #6
Hi Dan,
Looking forward to it.
Oliver
TH path length opinion neededHide this!Advertise here!
DAC - Opinion needed Faust3D Digital Source 45 20th November 2007 10:25 PM
Omnes audio L8spec - opinion needed barackuda Full Range 3 11th September 2007 11:42 AM
your opinion needed....... barackuda Tubes / Valves 3 30th August 2007 10:53 PM
Rf path length considerations eddog Chip Amps 3 2nd May 2006 04:07 PM
Opinion on those electrolytics needed Peter Daniel Parts 3 25th November 2003 05:12 PM
Copyright ©1999-2017 diyAudio
