Build your own 2x12" TH (The Kraken 212 TH) - Page 31 - diyAudio
Old 23rd November 2012, 10:26 PM   #301
I'm looking to take the plunge with the 1x12 Kraken with the JBL as directed, And just today picked up a retired from a movie theater QSC MX 1500a amp. I know it's way more amp than I need for this subwoofer, but there is always the future. I was planning on putting a miniDSP on the system. I thought to install it in the open accessory bay, only to find my bay isn't open. I find the QSC FS-1 Subwoofer filter in it. It's currently set to 100hz low pass and 32hz high pass.
Filter type:
second-order butterworth, Q=0.707
(LPF and unboosted subsonic filter)
second-order, +6 dB boost, Q=2
(boosted subsonic filter)
Is this a good starting point without a miniDSP?
Is there another frequency I should start with
hz ohm
20 82K Factory set for RN3
25 68K
32 56K
35 47K
40 39K
50 33K
63 27K
80 20K
100 18K
135 12K
160 10K
200 8.2K
250 6.8K Factory set for RN4
should I still use the miniDSP?
should I consider the dual voice coil version of this speaker instead of the single?
thanks,
Old 23rd November 2012, 11:52 PM   #302
esavage is offline esavage  United States
I hope I don't get kicked off the forums for not being a good searcher, but here goes:
Can anyone explain to me how having two speakers in the box effects the measurements?
In other words, which speaker do I measure from? Or does it completely change everything?
EDIT: To clarify, I'm talking about measuring the segment lengths as per Hornresp. Also, using the push-pull arrangement.
Old 24th November 2012, 07:18 AM   #303
epa is online now epa  Netherlands
Filter type:
hz ohm
25 68K
32 56K
35 47K
40 39K
50 33K
63 27K
80 20K
100 18K
135 12K
160 10K
200 8.2K
thanks,
i found a post a few pages back saying 18hz hpf
so you could do 20 hz or 16 hz if you buy a rn of 100k
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 26th November 2012, 08:56 AM   #304
can't load images on page1
Old 26th November 2012, 12:35 PM   #305
More broken links due to Members refusing to use the attachment facility provided by this Forum !!!!!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th November 2012, 09:08 PM   #306
Honestly, if I could see the original images, I could probably extrapolate everything I needed to know.
Old 27th November 2012, 11:11 PM   #307
I pm'd the author...his inbox are full
Old 30th November 2012, 01:05 AM   #308
I've been able to comb through and find enough images to figure things out, I'll let everyone know how that goes!
Old 30th November 2012, 10:34 AM   #309
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Is this what you guys are looking for?
Old 30th November 2012, 01:45 PM   #310
Default A Picture
I copied most of the images in the first thread just last summer.
There was also this.
Dave
Building Some 2x12 Cabs... SnoopKatt Multi-Way 16 8th December 2010 04:15 PM
212 guitar closed back cab build Yanoplathizo Multi-Way 2 22nd December 2009 12:56 AM
2x12 wiring help dclancy Instruments and Amps 2 7th October 2007 11:41 PM
Alchemist Kraken Apd6a Mkii santosa Solid State 0 20th August 2005 11:37 AM
1kW 2x12 rossco Multi-Way 4 15th March 2004 10:54 AM
Copyright 1999-2017 diyAudio
