#121 |
Hi again,
My comment in Post #118 was for the original Kraken 212. Regards,
Oliver |
#122 |
Aha, then it makes sense. It's true then. There will be some loss in low freq. and the first dip around 80 Hz will be a bit deeper.
#123 | |
I'll move the Kraken 1x12 forward 4 meters along the side wall to adjust for delay. This will put the mouth about a meter from my ears instead of 4 meters so the large increase in loudness at the seat position will make my little amp happy. Roamed over to the lumber shop and they could not get 22mm--then you post the designs for 3/4 or 19mm so all is well. This will be easier than I thought! Thanks again and have a wonderful weekend.
#124 |
Welcome and nice weekent to you too
#125 |
Just remember the distances are set to the longest dimension. One edge 90 degrees and the other angled. The 904/906-mm piece has angles in both ends.
#126 |
I am thinking about building this subwoofer, but I'm in doubt if i should build the 212 version or the 210 version.
So my question is: Frequency response the same for both? But only a lower SPL for the 210? Or does the 212 go a bit lower? I did some measurement in my room and I can just fit in the 212 version (I got 1145 mm space )So that's why I am considering the 210 version. Thank in Advance! |
#127 |
Never mind my last question. After I read the thread again I already found my answer.
I decided that I should build the 212 version. I just ordered the subs. They should arrive next week. I am going to build this bad boy in the holidays! Petter, thanks a lot for the design! Kind Regards -------------------------------------------- Job |
#128 |
FYI I finished the build of this subwoofer.
It sounds very good and is very loud. Unfortunately I don't have a good microphone so I can't do some real world measurement. Pictures will come if I can get my hands on a decent camera. Thanks again Petter |
#129 |
Thank you very much jobbywl! I am very glad that you both built it
and liked the sound! Please post some pictures
#130 |
There is a guy building one in Sweden now
![]() HiFiForum.nu - Möjligt ganska stort bashorn? In swedish, but you can see some images. |
| Building Some 2x12 Cabs... | SnoopKatt | Multi-Way | 16 | 8th December 2010 03:15 PM |
| 212 guitar closed back cab build | Yanoplathizo | Multi-Way | 2 | 21st December 2009 11:56 PM |
| 2x12 wiring help | dclancy | Instruments and Amps | 2 | 7th October 2007 10:41 PM |
| Alchemist Kraken Apd6a Mkii | santosa | Solid State | 0 | 20th August 2005 10:37 AM |
| 1kW 2x12 | rossco | Multi-Way | 4 | 15th March 2004 09:54 AM |
