Build your own 2x12" TH (The Kraken 212 TH)
Old 30th November 2012, 01:14 PM   #311
tb46 is offline tb46  United States
Or these?
Oliver
Old 30th November 2012, 08:39 PM   #312
esavage is offline esavage  United States
Excellent! Thank you so much!!
Old 30th November 2012, 10:30 PM   #313
panjilaras is offline panjilaras  Indonesia
Thank you guys. Should add access panel, just in case the drivers blow
Old 2nd December 2012, 08:20 PM   #314
18Hurts is offline 18Hurts  United States
I would add an access panel on the low pressure, final fold of the horn side.
Don't put a panel on the high pressure side! Just use bolts and make them studs (like on a car wheel) for the speakers to bolt to. Not too difficult and with the
panel on the low pressure side, it will be much easier to keep the seal. If it leaks on the low pressure side, it will sound weird. If it leaks on the high pressure side, it can cause the driver to loose pressure and exceed Xmax.
Old 3rd December 2012, 03:30 AM   #315
Thank for advice mr Hurts, that means the upper driver will be bolted from rear (magnet side)
Old 3rd December 2012, 09:53 PM   #316
Lordgunnar is offline Lordgunnar
i want to build a tapped horn. I can get these two drivers for a good price.
Eminence Eminator 2012
Eminence Eminator 2512
I just want to you 1 driver. Are there any plans for a tapped horn for one of these drivers?
Old 4th December 2012, 08:29 AM   #317
I want to use the tapped horn for movies.
Old 4th December 2012, 10:30 AM   #318
R.I.P.
Why twice?
regards Andrew T.
Old 4th December 2012, 04:01 PM   #319
Hi Lordgunnar,
May I suggest you go back to the subwoofer forum main page, and use the "Search this Forum" function, just search for Eminator. That way you may end up in the right thread.
Oliver
Old 4th December 2012, 07:23 PM   #320
Sorry for double Post, i am not familier with forums.
I read the thread and now i know what i want to build. I will build the kraken 112.
I want to build as cheap as possible. Therefore some questions.
The Infinity 1260w looks very similar to the jbl gto 1214, but is 40€ cheaper. Can I use the Infinity?
http://www.jbl.com/resources/Brands/.../GTO1214TD.pdf
http://manuals.harman.com/INF/CAR/Bo...260W_final.pdf
Is it possible to use thiner plywood than 19mm or mdf 19mm?
What is the best glue for this build, availible in Europe?
Build your own 2x12" TH (The Kraken 212 TH)Hide this!Advertise here!
Building Some 2x12 Cabs... SnoopKatt Multi-Way 16 8th December 2010 03:15 PM
212 guitar closed back cab build Yanoplathizo Multi-Way 2 21st December 2009 11:56 PM
2x12 wiring help dclancy Instruments and Amps 2 7th October 2007 10:41 PM
Alchemist Kraken Apd6a Mkii santosa Solid State 0 20th August 2005 10:37 AM
1kW 2x12 rossco Multi-Way 4 15th March 2004 09:54 AM
