Build your own 2x12" TH (The Kraken 212 TH) Build your own 2x12" TH (The Kraken 212 TH) - Page 30 - diyAudio
Old 8th May 2012, 06:02 PM   #291
Petter Persson is offline Petter Persson  Sweden
Well - you could, but the low freq.responce is not as smooth. some 2 dB
difference on simulation. I would sell the eminence drivers and buy JBL instead.
Old 25th June 2012, 03:24 PM   #292
ryan750 is offline ryan750  Philippines
hi!
How about using the JBL GT5-12 in replacement for the recommended JBL 1214?
Thanks!
http://www.jbl.com/resources/Brands/...ech_050108.pdf
Old 27th June 2012, 06:58 PM   #293
Sorry, the response looks resonant. Lower Bl and higher Re combined with a very low VAS.
Old 28th June 2012, 03:48 PM   #294
How will the Kraken 112 compares to the 212? Thanks!
Old 28th June 2012, 07:37 PM   #295
Half the SPL and you loose the benefits of push pull driver arrangement.
Old 31st August 2012, 06:27 AM   #296
Digity8 is offline Digity8  Canada
Would a creative sound trio12 work in this TH?
Old 3rd September 2012, 02:44 AM   #297
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
It sims very well in Akabak, near identical response as the intended JBL drivers. If it fits physically in the design it will be fine. 24dB Butterworth HP filter @ 18Hz, LP filter looks to be good around 70Hz
Old 3rd September 2012, 03:11 AM   #298
TundraLTD's Avatar
I just checked you'll need to make a spacer, the driver is 1.35cm (.53") to deep and considering the CSS Trio12 has a vented back plate I'd go with at least a 1" spacer for the driver closest to the mouth
Old 3rd September 2012, 05:34 AM   #299
Thank you Tundra, sorry I was`t specific, but would I still need a spacer for the single driver 12 version?
Old 3rd September 2012, 06:36 PM   #300
TundraLTD's Avatar
I haven't written an Akabak script for the 112 or 210 versions but I'll start on them. It should be fine and will fit with the driver facing into the beginning (small side) of the horn with about 4.5cm to spare between the motor and the outer wall
Build your own 2x12" TH (The Kraken 212 TH)Hide this!Advertise here!
Building Some 2x12 Cabs... SnoopKatt Multi-Way 16 8th December 2010 03:15 PM
212 guitar closed back cab build Yanoplathizo Multi-Way 2 21st December 2009 11:56 PM
2x12 wiring help dclancy Instruments and Amps 2 7th October 2007 10:41 PM
Alchemist Kraken Apd6a Mkii santosa Solid State 0 20th August 2005 10:37 AM
1kW 2x12 rossco Multi-Way 4 15th March 2004 09:54 AM
Copyright ©1999-2017 diyAudio
