Build your own 2x12" TH (The Kraken 212 TH) Build your own 2x12" TH (The Kraken 212 TH) - Page 22 - diyAudio
Old 31st January 2012, 01:05 AM   #211
Djim is offline Djim  Netherlands
Old 31st January 2012, 03:15 AM   #212
tb46 is offline tb46  United States
Hi Djim,
If that's the case, then this microphone is a joke (only a really bad one).
Oliver
Old 31st January 2012, 03:38 AM   #213
Hi Oliver,
Measurements come from well known German company, so measuring with this mic without knowing its error rate could be qualified that way.
There are a few Dutch DIY sites that provide useful info to build your own with a Sennheiser KE4-211-2i-1 capsule (89 Euro). The Behringer housing could be usefull for that :-)
Old 31st January 2012, 03:52 AM   #214
Hi Djim,
Thanks for the additional info.
Oliver
Old 31st January 2012, 06:59 AM   #215
barco is offline barco  Sweden
Yes, I saw this graph when I was googling around for some info on the mic. That is why I added microphone performance as a possible (and likely) source of "unknown".
I will look into finding a better mic, but I am not really into spending a lot of money (although without good measurement, the EQ doesnt really make any sense....)
Old 31st January 2012, 06:07 PM   #216
Hi Barco,
The link in my earlier post is quiet simple to build and costs about 110 Euro in parts. This Sennheiser capsule is also used in more serious measuring mics. Sennheiser does deliver a measuring chart that is pretty accurate.
The Monacor ECM-40 is a budget measuring mic (70 Euro) that seems to have better production lines and a better capsule compared to the Behringer. But its a fact that budget mics have their limits below 40Hz (for budget SPL meters its the same).
Old 1st February 2012, 07:30 PM   #217
Hi Djim,
Thought you might find this interesting: ARTA Chamber for the Lower End Microphone Calibration:
http://www.fesb.hr/~mateljan/arta/Ap...r-Rev03Eng.pdf
Oliver
Old 1st February 2012, 07:38 PM   #218
Hi Oliver,
Thanks for sharing, but to be honest, I'm not so sure how precise that method will work for (infra) low frequencies. Link
Old 1st February 2012, 09:00 PM   #219
Hi Djim,
The method seems to be good at least to 1Hz looking at the graphs provided. Any lower than that I simply don't care.
Oliver
Old 1st February 2012, 09:18 PM   #220
Interesting discussion!
I started looking into solutions for this "problem" with uncalibrated microphones and ran into this SOFSCI SoundSweeper Acoustic Measurement Kit | Sounds of Science
They claim:
2dB 10Hz to 19Hz
1dB 20Hz to 20kHz
1.5dB 20kHz to 24kHz
Which must be considered to be very good?
Build your own 2x12" TH (The Kraken 212 TH)Hide this!Advertise here!
Building Some 2x12 Cabs... SnoopKatt Multi-Way 16 8th December 2010 03:15 PM
212 guitar closed back cab build Yanoplathizo Multi-Way 2 21st December 2009 11:56 PM
2x12 wiring help dclancy Instruments and Amps 2 7th October 2007 10:41 PM
Alchemist Kraken Apd6a Mkii santosa Solid State 0 20th August 2005 10:37 AM
1kW 2x12 rossco Multi-Way 4 15th March 2004 09:54 AM
Copyright ©1999-2017 diyAudio
