#2 |
Looks great, i hope the cat approves it as well
#3 |
#4 |
What driver are you using in it? And would you post the Hornresp screens please?
#5 |
Hi Brett,
I will post all Hornresp sims, driver details and real measurements as soon as I get finished. ![]() thanks HF |
#6 |
how low are you aiming for with that design?
your assistant looks like a mini white wookie |
#7 |
News:
![]() ![]() ![]() Measurement results: ![]() (Has some room interference) Hornresp results: ![]() ![]() The result is truly amazing. The driver is brand new stock, hope gets better (if possible). The sound is amazing. Nothing better than a 6,5" driver in subwoofer enclosure to combine with 4,5" full range drivers. Much better than my last 10" TL. I can't believe the bass it generates. 30Hz easily. Remark: My room is small. Driver is a Brazilian Akron KB6. ![]() This is all the beginning. I need to play with the position and do more listening yet. Also need to solve some air leakage in the driver cabinet cover and also in the bornes. more reports soon! thanks HF |
#8 |
Great design!
xlnt work and result /JZ
Tala är tiga, silver är guld |
#9 |
#10 |
The measured graph was made with my existing crossover. I will need to use a 4th order to handle the peaks above 100Hz.
HF |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Help with a tapped horn. | mike james 533 | Subwoofers | 32 | 11th November 2009 02:34 AM |
| Tapped Horn behavior | screamersusa | Subwoofers | 32 | 21st October 2008 03:31 AM |
| Tapped Horn for Midrange | Patrick Bateman | Full Range | 2 | 30th October 2006 02:09 PM |
| Page generated in 0.10079 seconds (83.03% PHP - 16.97% MySQL) with 10 queries |
