Old 5th February 2010, 04:09 PM   #1
Send a message via MSN to chchyong89
Default how to wiring 8ohm three voice coil speaker
I have 3 voice coils sub driver,
i have stereo (2X LM3886, one for 60+/-watt), if i connect LM3886 to per single voice coil, sum up will be 60+60watt? or 60watt only?
and what the purpose of the third voice coil since we only got stereo.
thanks
Old 6th February 2010, 09:35 AM   #2
The additional voice coil is probably to offer additional flexibility for impedance matching. It sounds like you have a Car Audio subwoofer, and three 8 ohm coils wired in parallel would present a 2.66 ohm load to the amplifier, allowing the subwoofer amplifier to deliver more power.
Anyhow, if you have three LM3886, you could juice each coil with it's own 60 watts, giving you 180 watts total.
Good luck!
Old 6th February 2010, 11:01 AM   #3
measure the DC resistance of each voice. That will give a clue on whether they are similar.
It will also give a clue on whether the VCs should be wired in parallel, or series, or series parallel, or that one VC is completely different from the others and intended for another purpose, eg. feedback.
regards Andrew T.
Old 6th February 2010, 11:30 AM   #4
davygrvy's Avatar
agreed, three is an odd number. haha, pun intended.
Think out of the box
Voice coil diaphragm speaker Ed Holland Planars & Exotics 19 10th February 2009 06:58 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
Dual voice coil wiring questions devils_advocate Multi-Way 5 25th May 2006 12:37 PM
Wiring 2 Dual Voice Coil Subs To 2 Amps BEAN27 Car Audio 1 14th April 2006 11:23 PM
Dual voice coil wiring question bigshooter13 Multi-Way 18 4th October 2003 09:18 AM
Page generated in 0.07598 seconds (63.84% PHP - 36.16% MySQL) with 10 queries
