best 15" 4ohm sub for a TH ??
Closed Thread
Old 28th January 2010, 10:50 PM   #1
justint is offline justint  United States
Default best 15" 4ohm sub for a TH ??
i am looking for a 15" subwoofer that would be good for a TH project it needs to be 4ohm though.. Please send me your best suggestion.. Also needs to run at least 500 rms closer to 1000 watts continuous would be better.
Old 28th January 2010, 11:23 PM   #2
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
What are your goals for SPL, low cutoff, power applied, size of cabinet, number of cabinets, where will they be used?
Dan
Old 28th January 2010, 11:27 PM   #3
MartinQ is offline MartinQ  Canada
I agree completely. Stating driver size and power handling is the backwards way of designing a sound system. It should be the other way around:
1. what are the sound requirements
2. what is the most effective way of getting there
Old 29th January 2010, 12:24 AM   #4
Goals are as such
1.SPL high as possible with some sound quality i don't want a one note wonder
2.low cutoff used for playing pop rap music so ?? 40hz
3. power applied 1100 watts rms 4ohm load amp
4. size of cabinet - 5.9 cubic feet roughly.. this is relation to my TH box posting from yesterday.. box would be 58"x10"x18"
5. number of cabinets - 1
6. where will they be used? my wakeboad boat.
Also if you look at my post from yesterday the last comment and design is showing the TH with a side exiting port.. I have not built a TH before does a side exiting port work? Hope this info helps.
Old 29th January 2010, 12:42 AM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Thread closed. See here:
http://www.diyaudio.com/forums/subwo...oard-boat.html
planet10 needs your help:
Let's help Ruth and Dave
Closed Thread
best 15" 4ohm sub for a TH ??Hide this!Advertise here!
Harrison type "K4000" (K 4000) MKII 2x1000W/4ohm tiefbassuebertr Solid State 35 15th January 2017 02:46 PM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
Australia: Lorantz 10" 4ohm 200w mid-bass col Group Buys 3 10th August 2008 10:03 PM
15" Immortal Subwoofer awis-15 bil Car Audio 0 30th May 2006 07:46 PM
Tempest 15" or Dayton 15" DVC Sub? longblock454 Subwoofers 1 31st January 2004 06:24 AM
Copyright ©1999-2017 diyAudio
