a good amps to play 8 lab horn
Old 28th January 2010, 05:22 PM   #1
soundhead is offline soundhead
Default a good amps to play 8 lab horn
looking for a amps to play 8 lab horn
Old 28th January 2010, 07:03 PM   #2
davygrvy is offline davygrvy  United States
davygrvy's Avatar
The lab12 driver is 5 ohms with a music power rating of 800W. A nice round number would be 1200W for the amp to allow headroom for your limiter. That's 1200W per cab. two in parallel make 2.5 ohms. Most good pro amps can do that per channel. So you're looking for 4 channels @ 2400W each. Welcome to the 10K club!
Think out of the box
Old 28th January 2010, 07:14 PM   #3
Lab 12 driver is 5 or 6 ohm
Old 28th January 2010, 07:31 PM   #4
Davy can you recomend any good amps to play the 8 lab horn
Old 28th January 2010, 08:38 PM   #5
godfrey is offline godfrey  South Africa
A standard Labhorn uses 2 Lab12 drivers per cabinet, doesn't it?
So need to double up Davy's numbers?
a good amps to play 8 lab hornHide this!Advertise here!
is lab horn the best soundhead Subwoofers 47 15th August 2012 11:50 PM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 06:12 AM
Why Does The Lab Horn use Two Woofers? john van ommen Multi-Way 0 13th September 2006 06:27 PM
Copyright ©1999-2017 diyAudio
