Old 9th February 2010, 06:20 PM   #31
davygrvy's Avatar
Originally Posted by MartinQ View Post
These two measurements look very close to each other to me.
Me too. The LMS plot was done with a Titan48 that had the extended frequency throat mod. So the two cabs are different.
Think out of the box
Old 9th February 2010, 06:31 PM   #32
MartinQ is offline MartinQ  Canada
Thanks for that added info davygrvy. There is definitely a difference between the two plots but not as significant as it would first appear. To better illustrate this I've cropped and combined the two graphs to approximate the x & y scales.
Old 9th February 2010, 06:57 PM   #33
Davy: "Yes, see Danley's graph I posted. He hits 50%..."
Thanks Davy! I stand corrected.
Don
Old 9th February 2010, 08:18 PM   #34
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Is that the same efficiency peak as found in HR?(below) Or are you saying Danley claims a broadband efficiency of some sort.
28.28v/100w
Click the image to open in full size.Click the image to open in full size.
Dan
Old 9th February 2010, 08:31 PM   #35
NEO Dan's Avatar
So I found Danley's spl graph and tried it in the sim 100w total into 4 cabs wired series parallel
It looks like there is coupling of the TH's
Dan
Old 10th February 2010, 03:50 AM   #36
djk is offline djk
djk's Avatar
Even simple direct radiators may reach 25% in multiples.
Candidates for the Darwin Award should not read this author.
Old 15th March 2012, 11:24 PM   #37
The thing behind this is the following. In order to get 3 dB more out of a loudspeaker, you need to double the power input. However, two coincident sound sources of similar strength combine to produce 6 dB more as compared to a single one. So, that is 3 dB more for the same increase in wattage. In other words, efficiency doubles. For another doubling in efficiency, you need to double the number of speakers again, so you need four. Start with a 5 % efficient speaker, and a combination of two will be 10%, four 20% and eight 40% efficient. This is only theoretically possible.
'Coincident' requires not only that the sound sources are aligned in time, but also that they emanate from the same point in space. Since this is not possible with real speakers, this latter requirement can only be approximated for wavelengths that are large compared to the size of the stack.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall.
Old 16th March 2012, 01:04 AM   #38
djk is offline djk
djk's Avatar
A 7" wide LF source fed by multiple drivers for high efficiency.
Old 16th March 2012, 06:51 PM   #39
Originally Posted by soundhead View Post
So is there any bass horn that can go up against the lab horn. Box per box
Box per box?
No size restrictions?
A bigger FLH box plays louder, the 12Pi is 32.8 cubic feet and can do 131dB at 35 Hz using the same Lab 12 drivers it will be slightly louder than the smaller 26.4 cube Labsub.
Relax your size restrictions even more, and a 100 cubic foot horn driven by just two Lab 12s will get flat response from 38-100Hz at 140dB without exceeding Xmax!
As far as output per driver, FLH generally are the winner, TH are a close second, BP, third, BR forth.
As far as output per enclosed space, the order reverses, so if the question is "how much SPL output can fit in X space", rather than "how much SPL output is possible from driver X", the answer is different.
That said, by relaxing LF requirements by 5 Hz, yesterday messing with Hornresp found one can get 126 dB at 40 Hz rising to 129 dB at 100Hz from a single Lab 12 in a small (7.76 cubic foot) FLH box.
When the conversion from dual BR to single FLH is done, I'll post the results.
This box is smaller than the SS15, nearly as loud, goes way lower, and uses a speaker that costs less.
Will be laying it out later today, it should only use close to one 4x8 foot sheet of plywood.
Art Welter
Old 16th March 2012, 07:47 PM   #40
Dam this thread is still alive.
Ok Art I will stay tune
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Why Does The Lab Horn use Two Woofers? john van ommen Multi-Way 0 13th September 2006 05:27 PM
Searching for plans of Lab Horn sub Bull Multi-Way 4 15th November 2003 09:57 PM
Page generated in 0.11340 seconds (79.70% PHP - 20.30% MySQL) with 11 queries
