Here's the specs:
Fs 26.6Hz Qts 0.23 Qes 0.24 Qms 5.7 Re 3.2 Ohms Vas 2.2 ft^3 I've got 4 of them. Open to all ideas that don't require any active EQ circuitry. Sensitivity is more important than extension. Planned use is to serve as PA subs for one party a year, so they don't need to go low. Normal pro-sound requirements about durability don't apply as much since it's a once a year party. Size is not of much concern other than the cost of the wood to build it. So, ideas? Thanks a bunch! Last edited by santiu; 25th January 2010 at 08:09 PM. |
#2 |
Low fs and qts suggests a ported box.
With 4 of them, you could go low, and loud enough for most house parties... Any ideas on Xmax, power handling, sensitivity?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
Xmax 13mm
power handling 200W no idea on sensitivity |
#4 |
Build Bandpass Boxes. one octave range say 35-70 Hz. U can use the shareware program Unibox (Excel SS) to design. This program lets you optimize either for gain or for wider bandwith.
4th order Bandpass Box is with the driver buried inside between a sealed chamber and a ported chamber to the outside. Simple to build with better efficiency than a single ported box, Depending on make of driver it would be best re-measuring basic T/S to have better chances for success.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
| Looking for phase plug ideas for horn loaded 10" and 12" drivers | Eva | Multi-Way | 10 | 11th December 2011 05:17 PM |
| Coral Flat-10 (Beta Look-Alike) 10" Fullrange Drivers | thetubeguy1954 | Full Range | 37 | 20th August 2011 11:47 AM |
| 70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. | facundonu | Multi-Way | 34 | 9th March 2009 04:59 AM |
| Onken for 10" or 12" drivers. | maal1605 | Multi-Way | 1 | 29th November 2008 01:52 PM |
| Page generated in 0.06877 seconds (71.13% PHP - 28.87% MySQL) with 10 queries |
