I was looking at Volvotreter's 38Hz Tangband Tapped Horn using a 6" driver. Tangband also makes a 8" driver. Given I have no design software and I know the dimensions of the 6" horn cabinet, can I just scale the dimension up to fit the 8" driver? Correct me if I'm totally off here, but I was thinking the 8" would go lower and still not be a huge cabinet like a 12" or 15" would be. I could even fit two in my system if needed.
#2 |
On this sort of design, you don't want to guess and you don't want to assume.
No need to guess since HORNRESP is available, free and easy to use. Don't assume drivers from the same manufacturer are going to have "similar" T/S parameters. You need to look them up and feed them into HORNRESP. There are plenty of HORNRESP examples to get you started |
#3 | |
The short answer is no. |
#4 |
I did download the software but on initial glance it might as well be in braille. I looked through the help but it doesn't make sense to me. The speaker specs don't seem to plug in. It looks more like you tell it what horn you want and it tells you something else. Sorry for the total confusion but this thing just makes me feel stupid.
I built this from scratch: ![]() But this seems to be beyond me: |
#5 |
You can go to the tapped horn section on William Cowan`s site. William Cowan's Homepage
Scroll all the way down and you find a TH script for AKABAK to copy. Hope this helps. Peter
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor... |
#6 | |
#7 | |
There are already HORNRESP setup ups for VOLVOTRETER's TH sub. Modifying one of these would seem to be easier. However, at some point he is going need to roll up his sleeves and get some degree of understanding about HORNRESP. I think it is worth the effort. |
#8 | |
Guide to WinISD Pro and Hornresp - Speakerplans.com Forums - Page 1
Regards Johan
Impossibilities we do immediatly, miracles take slightly longer. Last edited by Rademakers; 25th January 2010 at 10:02 PM. |
#9 | |
#10 |
Another hornresp/tapped horn tutorial:
Simple Tapped Horn Tutorial using Hornresp - AVS Forum Good luck. (and beautiful work!) |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Help with a tapped horn. | mike james 533 | Subwoofers | 32 | 11th November 2009 02:34 AM |
| horn (tapped or otherwise) suggestions | needmorstuff | Subwoofers | 11 | 31st August 2009 10:31 PM |
| Tapped Horn for Midrange | Patrick Bateman | Full Range | 2 | 30th October 2006 02:09 PM |
| Page generated in 0.11054 seconds (84.49% PHP - 15.51% MySQL) with 10 queries |
