source for Eminence HL10C found
free air resonance is like 41hz compared to the lab-12's 22Hz or so. These calculate to anorexic sized rear chambers ;) Says free shipping, you live in Australia or something?
the netherlands, also quite far away.. i simply love LAB-12's, so versatile, trusty and multi-purpose! but they are expensive here compared to the USA. never under 300 dollars .
flux audio labs B10-4
would this 10" be a useful replacement for the Hl10c?
fluxaudiolabs.com
B10-4
T/S Parameters
RE 2.34 ohms
LE 1.36 mH
QMS 10.51
QES 0.34
QTS 0.33
Xmax 11.90 mm
RMS 250 watts
BL 11.23 Tm
FS 28.1 Hz
Mms 102.5 grams
Mmd 99.0 grams
Cms 0.312 mm/N
Vas 49.6 liters
SD 334.5 cm^2
VD 398.1 cm^3
Magnet Weight 67 ounces
SPL 87.0 db 1W-1m
