dual 8" TH build x6 - Page 2 - diyAudio
Old 24th January 2010, 08:21 AM   #11
Originally Posted by jason_watkins View Post
Lookin' good bko. I recall you're near pdx metro area?
I just got the shipment notification on my mcm's. I'm targeting 30hz or lower for HT however. I think I'll steal your rather nice handle idea .
Be sure to use an appropriate high-pass to protect your drivers. I've got a pair of MCM 55-2421s in a 30-Hz tapped horn currently, they will bottom out with extreme LFE (Batman Begins) when turned up (~105 dB at the couch, so only ~50 watts into the pair).
Old 26th January 2010, 12:12 AM   #12
bko69 is offline bko69  United States
My THs are finally done! They look good and they sound good to my ear, but i'm a little embarrassed to post the final measurements. I'm not sure what went wrong. My test box had better measurements. Must be the 45s i put in the corners for the handles.
the full photo set can be seen here: Tapped Horn build
30hz 30db
35hz 49db
40hz 64db
45hz 70db
50hz 73db
55hz 76db
60hz 78db
65hz 80db
70hz 81db
75hz 82db
80hz 83db
85hz 84db
90hz 84db
95hz 86db
100hz 87db
bob
Old 26th January 2010, 01:01 AM   #13
jbell is offline jbell  United States
LIVE SOUND Specific Tapped Horn thread...
yep, each reflector can make a big difference.....
Old 18th June 2015, 03:38 AM   #14
Nice job! would like to build a pair for a friend!
New Build: Coniston^2 dual driver double mouth MBVR italynstylion Full Range 40 18th January 2011 08:53 PM
Planning to build an Aleph 5 dual mono amps - advice commandercam Pass Labs 1 20th October 2009 12:04 PM
GE "Dual Speaker" radio to Harmony H303 conversion : Help, please? Spasticteapot Tubes / Valves 16 12th July 2007 10:00 PM
AudioSector LM4780 Dual-Mono - questions/build log gongzero Chip Amps 3 22nd October 2006 03:43 PM
Copyright 1999-2017 diyAudio
