Hi
I am looking to replace my DIY sub with 2 smaller boxes so I can have more options with placement. The existing sub is 2 Dayton 15" series 2 drivers in a 6cu. ft. box. I am looking to stay under about 3 cu ft on the new ones. I could just transfer the old drivers to new boxes but thought it is a good chance to upgrade to a better driver.
I have been looking at the CSS sdx 15 or 2 sdx10 in a sealed box 3.4 cuft for the 15 and about 2.7 for the 10's. I realize that the 15 on paper will put out more volume with it's 30mm xmax but I am more concerned with sound quality and the 2 10's would play louder as a stereo pair than what I have now. The 10's would be 8 or 2 ohms depending on how they are wired and the 10 is a more ideal load of 4 ohms and would also be about 3db more efficient at 20hz and need less eq.
I am leaning towards these drivers because they are available in Canada and are easier and cheaper to get then ordering from the US. I am looking for input from anyone who has experience with these drivers in sealed boxes for music listening.
I am also considering the GR research or Rythmikaudio servo subs but they will cost me much more and I don't know if the difference will be worth it. Any input on this is appreciated
Brian
Brian
So you are talking about 4 SDX10 in 2 boxes or 2 SDX15 in 2 boxes?
I'd go with push-push SDX10s. Something similar to what i'm doing with a quad of Bob's Trio8s. I also have a pair of SDX10, but current plans are to use them as woofers in something special.
dave
dave
dave
Hi Dave
Yes, I am thinking of 2 boxes with 2 10's in each box OR 2 boxes with a 15 in each. I am just trying to get info. on the quality of bass for music that I can expect from these drivers. I will be using a seperate amp and crossover/eq to drive them. If you have heard the 10 or 15 in a sealed box please let me know your impressions. The trio 8 looks like a nice driver. I have been waiting for the sdx12 to make an appearance but there is no news yet. Do you have any idea how high the sdx10 can be used. There don't seem to be any response plots on the css site but the impedance plot looks smooth in the mid bass. I might want to go as high as 150 hz for some experiments I am doing.
Brian
if you mount the 2 SDX10's on oposite sides of the box (@Dave: is this what you mean with push-push?) then this will give you a very clean sound due to a big reduction in cabinet resonances.
the FR of the SDX10 is rather smooth, no problem using them upto 150Hz.
Or, you get another set of the Dayton drivers and wire them isobarik, how's that for a left field idea?
If I try top look at specs for your proposed drivers, the site gives a "gateway time out." I presume you can calculate how much air each sub can move based on your Xmax comment. Understand however, that at very low frequencies QUALITY and QUANTITY of sound are quite interrelated. Due to hearing curves, you must generate a loud SPL at low frequencies or you cannot hear/feel it. Look up "Fletcher-Munson" if you're unfamiliar. In other words, you can't really say "I'll give up SPL for better sound quality" UNLESS either set of drivers can put out as much SPL as you need.
At very low frequencies, the 2x10s will load each other and you'll get a 3 dB boost compared to a single 15." But up to what frequency, that's another question you'd need room response software to answer.
If the twin tens don't displace very much less than the 15," go ahead with them. I feel from your post like you're leaning in that direction anyway, and then you have more options for cabinet shape. Don't forget to stuff the boxes very well to gain additional apparent cabinet volume and kill reflection.
Yes. Push-push typically means opposite sides of the box (althou i have had thot experiments with stuff that ends up much more convoluted)
If i carry my SDX10 project forward, they'll like get used up to about 125 Hz.
dave
Hi
The 2 10" drivers are about 1db more efficient than the single 15. However the rolloff is -3 at 44hz versus about 35hz for the 15. This gives the 15 an advantage in sensitivity in the bottom octave. I am now leaning towards going with the 15's for this reason. I am going to build the boxes and install my existing 15's and then upgrade later if I feel the need. The mounting dimensions are close enough to work.
As for brute output capability the sdx15 can on paper move more air (800cm x30mm xmax) then the 2 10's (660cm x 18mm xmax) roughly 6db more output. It would require a lot of power to get that much output.
No matter what output level I am playing them at, the 15 will always have slightly less excursion due to the higher sd. At a level where the 10's are maxed out the 15 would only be at 50% of xmax.
It looks like the sdx15 has quite a clean response and would play up to 150hz ok.
Thanks for the input
Brian
Brian
Have you actually used them that high? If so, could you post some details of the implementation?the FR of the SDX10 is rather smooth, no problem using them upto 150Hz.
Hi
Brian,
Toole has shown that F3 is essentially meaningless in terms of bass extension. Compare F10.
dave
Brian,
dave
Yeah, F3 ignores the shape/slope of the rolloff, ya gotta look at the whole curve.
For instance, if we limit to sealed boxes using the same driver, a box with a total Q of 0.5 would have a higher F3 compared to a Q of 0.7. But actually the Q=0.5 box would roll off more slowly, and IN-ROOM probably have more extended bass
no, I have no 1st hand experience with them in a set-up like this (I do have experience with a different sub crossed at 150Hz to sats), but if you take a look at the FR curve it is nice flat and smooth, unlike some other subs that start to loose SPL above 100Hz and/or show cone break-up.Have you actually used them that high? If so, could you post some details of the implementation?
Hi Dave
I have compared the response curves in Winisd. With the boxes I spec'd at the start of this thread the 2 10's would have a Q of .65 and f3 of 44hz. The 15" a Q of .71 f3 about 35hz. While you cannot look at F3 alone, F3 and the Q of the sealed alignment define the response below F3. The elephant in the China shop in all this is placement and room modes/room gain. I have developed an adjustable eq circuit that will allow variable boost to deal with room gain. I have been away from this hobby for a few years and am just getting back up to speed again. If anyone is using sdx15's in a sealed box for music I would like to know your opinions of how they perform.
Brian
Brian
Brian,
dave
Is there no one that has actually measured an SDX10 yet? I want to go as high as 200-300 Hz but due to earlier posts I doubt it will be possible? However, a measured response should really put my mind at ease either way.
I have a pair sitting here, but too many other drivers have gotten my attention. I won't be measuring anything but T/S anytime soon.
dave
dave
Then maybe consider the AE AV10H. The 12" versions have been used as high as 500Hz in some projects, so the 10" should easily meet your BW requirements.Is there no one that has actually measured an SDX10 yet? I want to go as high as 200-300 Hz but due to earlier posts I doubt it will be possible? However, a measured response should really put my mind at ease either way.
Hi
I have postponed my sub upgrade project. I actually converted my old 2 x 15" sub into 2 seperate 15" subs. This works better in my room. I am thinking about 2 gr research 12" servo subs in the future but it is not a priority now.
Brian
Brian
Yes, that driver went directly to my shortlist for further evaluation.
Hi
Brian
I've heard that seconded more than once, that often two smaller subs work better than one large.
Haven't you read the Harman multi-subs paper yet?I've heard that seconded more than once, that often two smaller subs work better than one large.
No, that one I've missed until now, and it will be read after I finish reading a dissertation on loudspeaker cabinet diffraction. Thank you for the direct link, that's appreciated.
- Subwoofers
- Music sub -2 sdx10 or 1 sdx15 ?
