Old 15th January 2010, 08:21 PM   #1
Default Port size and length?
Im not sure if i can just give you the specs on the driver and then help me figure out port size from that or not but speaker specs are:
Re .975/3.9 (dvc 2 ohm)
Fs 19hz
Qes .271
Qms 4.59
Qts .256
Vas 143 litres
xmax 13.5 mm
spl 90.2 db
I have a box from a past project that is about 3 cu ft (subtracting driver volume already done). Is there any way I can mount these two drivers in this box (its sealed right now) then cut and install a port to make these drivers work with 1.5 cu ft of volume for each driver?
Any help or comments appreciated...
Old 18th January 2010, 04:25 AM   #2
download Winisd or Unibox for free, they'll both do the calcs for you
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 18th January 2010, 12:02 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
http://www.imagedynamicsusa.com/pdf/...%20D2%20V2.pdf
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 18th January 2010, 01:14 PM   #4
tinitus is offline tinitus  Europe
Your box seems perfect fore two of those woofers, if it stays closed
Porting results in either a too small or too long port
Old 25th January 2010, 06:39 AM   #5
Er, you didn't give Sd or say what size woofers these are...
And, what's the brand & model #?
port length tald Multi-Way 7 14th January 2010 01:26 PM
port length jwhit67 Multi-Way 1 6th March 2008 12:29 PM
Help with port length please Bobhof Multi-Way 3 2nd May 2006 06:32 PM
port length busterno1 Multi-Way 5 27th October 2003 08:05 PM
port length dave k Multi-Way 13 13th July 2003 02:32 PM
Page generated in 0.07227 seconds (75.21% PHP - 24.79% MySQL) with 10 queries
