#11 |
"It will be 2 of these drivers in one cabinet, ported, not wanting to tune too low, as this will be used for strictly music, primarily kick drum (rock) type bass, and loud."
A 2235 would be a very poor choice. A 2242 while great, is a fortune. Personally, I would get four Eminence 15s. More performance, less money.
Candidates for the Darwin Award should not read this author. |
#12 |
If used in a home envirement, I dont see any reason why not. Given that they are driven active with eq applied. As mentoned above, I have two 2226H in a 100L closed enclosure, and powered by a Crown XTi 2000 and a low shelf filter its good for about 105db from 20hz and up.
#13 | |
#14 |
#15 |
#16 |
Hello,
Here is a recent thread on JBL 2225 and bandpass. These ideas should work for your 2226s as well. jbl 2225h need box calc |
#17 | |
#18 |
#19 |
Eminence, while good, is not in the same league as the 2226. JBL drivers have no peer. The closest would be Beyma. I've been considering the 2226 for open baffle use; powered by its own amp due to the low-ish Q. The FS is high, but fine for 95% of music.
I must confess my favorite music is that made by the Rolls Royce Merlin. |
#20 |
"Eminence, while good, is not in the same league as the 2226. "
Used properly, Eminence can outperform JBL, and at a fraction of the price. In the USA Eminence has a better warranty than JBL. When your JBL 2226 blows up I suggest you try the Eminence KAPPA PRO-15LF-2. It will cost less than a recone on the JBL 2226. All my cabinets are push-pull slot-loaded (PPSL) which has less bass distortion than shorting rings do, and no shorting rings to work loose and destroy the woofer (as has been known to do on JBL). ![]() My drivers are a custom design built for me by Eminence, and they cost about 1/6th what a 2226 sold for. I have a few JBL drivers laying around, mainly ones that were swapped out for my design. I keep the JBL around to compare against my drivers.
Candidates for the Darwin Award should not read this author. Last edited by djk; 17th January 2010 at 11:03 PM. |
| What makes the JBL 2226H such a popular driver? | Defo | Multi-Way | 13 | 11th November 2011 03:29 PM |
| Jbl 2226h | Hylle | Multi-Way | 5 | 1st October 2009 08:43 PM |
| WTB: JBL 2226G (pair) or blown 2226H/J and 1" compression drivers | mikey7182 | Swap Meet | 1 | 6th March 2009 03:43 AM |
| FS: JBL 2226H - $150 + shipping | taloyd | Swap Meet | 7 | 30th January 2008 09:31 PM |
| jbl 2226h built :^) | mikee12345 | Multi-Way | 14 | 24th July 2003 10:08 AM |
