Loud Hum From My Polk Audio PSW140
Old 12th January 2010, 10:17 PM   #1
reaper996 is offline reaper996  United States
Default Loud Hum From My Polk Audio PSW140
Hooking up my Polk Audio PSW140 subwoofer to my stereo this weekend I noticed that the SW would not power up. I pulled the amp plate and found a blown fuse, which I replaced and re-installed the amp plate. Upon plugging it in the SW began to make a loud hum.
I spoke with Tech Support at Polk Audio and they said it might be a regulator or output.
Any ideas what the problem might be or where to start troubleshooting?
Thanks in advance.
Old 13th January 2010, 12:33 AM   #2
DSP_Geek is offline DSP_Geek  Canada
I would look at the power supply filter caps. Polk had a problem with underrated caps once upon a time, so they'd blow after a while. On the other hand, you might also want to look at the output transistors:
Bad amp - PSW140 - Club Polk
Old 17th January 2010, 08:14 PM   #3
I have found the problem, it looks like one of the transistors and two of the resistors got damaged. The transistor looks like a TIP29C, and the tan-bodied resistor looks to have a 10 kohm value and the green-bodied resistor value I cannot determine. When I MM each of the resistors, I get the following values:
tan-bodied 1.828 kohms
green-bodied 2.494 kohms
The two similar, looking, resistors in front of the TIP30C transistor have the following values:
tan-bodied 1 ohm
green-bodied 12 ohms
Not sure what I have going on here.
Old 4th November 2014, 05:27 PM   #4
Techmansasa is offline Techmansasa
Need to replaced tip 30 and and 29 resistors values 3.3koms and 100koms and 2 caps behind TIPs 220mico35v all should work
Loud Hum From My Polk Audio PSW140Hide this!Advertise here!
broken sub, loud hum tekkas Solid State 10 23rd December 2013 06:04 PM
VERY loud hum issue 5th element Solid State 23 30th May 2004 05:37 AM
my amp makes a loud hum wonder_b Solid State 5 27th May 2004 10:50 AM
Loud hum problem gasjack Chip Amps 4 19th February 2004 12:16 PM
For those who have hum with theyr gainclone (loud or not) Bricolo Chip Amps 6 16th July 2003 07:57 PM
Copyright ©1999-2017 diyAudio
