Need help with HT sub enclosure
Old 12th January 2010, 03:16 AM   #1
tommyk90 is offline tommyk90  United States
Default Need help with HT sub enclosure
So my neighbor asked me to build a subwoofer enclosure for their new home theater setup. Here's the predicament, it's going under the floor and has only a 6"x10" opening that air can flow through. So my first thought was a 4th order bandpass. The problem I'm having is trying to figure out which way to go. Either a low-tuned sealed chamber with a high-tuned ported, or vice versa. Honestly I don't have the slightest clue as to which would work out better, so I need some help. It's most likely going to be for a single 12", nothing crazy. Probably get ~200-300 watts at most. They aren't crazy into movies and whatnot, but I'd like to build them something that performs well and has a fairly broad frequency response. Can anybody give me some tips? I posted this over on avsforums and have gotten no help.
Old 12th January 2010, 04:17 AM   #2
Sorry that its one big paragraph. I copy/pasted it and it was spaced but for some reason got mashed together. Anyways, if you guys need T/S parameters the sub is most likely going to be an eminence lab12.
Old 12th January 2010, 04:22 AM   #3
jbell is offline jbell  United States
you have 8' long and 14 1/2" between joists?
Theater Seat Riser Subwoofer
An mcm 55-2421 in an up and back tapped horn might be just the ticket...
Old 12th January 2010, 05:22 AM   #4
Honestly I'm not sure of the exact dimensions quite yet, but it has to be somewhat practical. Its going in between the floor joists and the basement ceiling drywall is already up, so it has to be able to fit through a decent size access panel. 8 feet long is definitely out of the question. haha. Like I said, it doesn't have to be anything crazy. My main question was with a 4th order design, should I go for a high tuned ported/low tuned sealed design, or a low tuned ported/high tuned sealed design?
Need help with HT sub enclosureHide this!Advertise here!
Switching car audio enclosure to home enclosure wattz Subwoofers 10 18th April 2010 06:51 PM
HT Center Speaker Enclosure Design jeromero Multi-Way 4 13th April 2007 08:13 PM
Fostex FE 167E flat enclosure fot HT promitheus Full Range 18 24th January 2007 02:37 AM
HT without a HT receiver paulspencer Digital Source 28 12th December 2003 09:29 PM
