I just recently bought 2 10" subs and a amp. I had a friend who knows how to install do it. It worked and played fo about 30 sec then thumped and went out.... No power to the amp at all. All of the fuses are good and all of the wiring is good. Touched a dc meter to the amp and its getting power, just the amp will not turn on. We plaugged the amp in my buddies car and it worked no problem.. What do you think is wrong with it?!!!? I hae tried absoluitly EVERYTHING and i cannot figure it out.
#2 |
check your grounding... also put this up in car audio.
Bigger the better... unless you like peace and quiet... But we can fix that too. |
#3 |
Yeah, put this in car audio.
Are you getting 12V? Not 8 or 9 or 11? Are you getting 12V at the turn-on lead??? Maybe you have main power, but nothing is signaling the amp to actually turn on. That's what it sounds like to me. |
| WTT: One set of F4 boards for one set of F3 boards | KT | Swap Meet | 0 | 16th May 2008 03:49 PM |
| SET on a budget | gingertube | Tubes / Valves | 4 | 7th October 2005 07:43 PM |
| Iron set for Paraglow (2A3) SET amplifier | Alain Favret | Swap Meet | 1 | 19th March 2004 06:23 AM |
| Room set up | Guss | Multi-Way | 1 | 20th July 2003 11:35 AM |
| How should I set this up? | harukan99 | Multi-Way | 1 | 11th April 2001 06:08 PM |
| Page generated in 0.07363 seconds (67.49% PHP - 32.51% MySQL) with 10 queries |
