Old 15th February 2010, 09:14 PM   #11
GM is offline GM  United States
GM's Avatar
Cornu Spiral Copy Horn
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th February 2010, 07:21 AM   #12
chris661's Avatar
Similar, but without the horn-related cross-sectional area changes.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 16th February 2010, 07:58 AM   #13
frugal-phile(tm)
planet10's Avatar
Originally Posted by chris661 View Post
Instead of just folding the baffle once (ripole, S-frame, whatever you want to call it), why not fold it lots of times around the driver? You'd get some kind of spiral, not sure what that would do...
Chris,
That is essentially what you get when you stack multiple ripoles
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th February 2010, 07:40 AM   #14
Originally Posted by tinitus View Post
It is
Someone created the "ripole" name fore commercial reasons
I think the original general describtion is "folded dipole"
I presented this, because I havent seen it this way before, with openings facing down and up
Drawing also shows kind of a marriage with H-frame, making the baffle effect more effective
Well, maybe kind of a dipole-omni hybrid
Hi Tinitus,
such a dipole standing on the floor with sound particle direction
orthogonal to the floor would have poor efficiency IMO.
1) For a Transducer based on sound particle velocity, the
position near a wall (floor) is in general the most
disadvantageous you can choose, because sound
particle velocity near walls tends to zero and the room
modes cannot be excited efficiently from there.
A wall (floor) can support a dipole sub only if the direction
of sound particle velocity is parallel to the wall.
2) Direction of sound particle velocity is bad especially
for exciting the lowest room modes which are usually
in the horizontal plane, because distances of the side walls
are longer than the distance from floor to ceiling.
3) You loose IMO one major advantage of a dipole sub:
The possibility to balance excitation of room modes by
rotating the direction of particle velocity !
This is a unique balancing technique which cannot be done
using monopolar subwoofers. Monopoloar subs have to be
moved around to balance excitation of room modes.
Dipoles can move AND rotate to modify in room response.
This is an additional degree of freedom usable for balancing
in room response which cannot be over estimated IMO.
Kind Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 18th February 2010, 09:22 AM   #15
tinitus is offline tinitus  Europe
Hmm, ok, you seem to know this
But it seems to me that some kind of "omni" dipole might work well
At least the one Im listening to right now
But its not something I tried properly, yet
The one I showed was an attempt on that, an "omni" dipole
No, I dont expect it to be very loud
I never play loud
So, you saying that if its turned around, and playing along the side walls, it will be better
Ahh, we could call it Z-fold, or Zorro
Old 18th February 2010, 10:44 AM   #16
Our new friend Chris might want to read these
Offene Schallwand (OB)
DIY-dipole-1
Old 18th February 2010, 12:21 PM   #17
jacq. is offline jacq.  Canada
Well I had my idea on the subject a few years back for a Z frame, here is what it looked like below. It works great for music but as you mite guess the system as limited headroom.
Jacq.
H frame vs W frame dipole woofers rick57 Multi-Way 18 8th October 2011 04:58 PM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 04:44 PM
H frame/ Dipole/U frame ???????? j.burtt Multi-Way 24 1st May 2006 03:50 AM
H-Frame mcds Multi-Way 3 17th April 2004 03:50 PM
Copyright ©1999-2013 diyAudio
