can some plug these data in to hornresp and let me know if this is a good speaker for folded horn at low feq.
15″
Qts
0.28
Re (series)
4.0 Ω
Fs
20 Hz
Cms
135 µM/N
Vas
127 lit
Mms
452 g
BL (series)
27.5tm Xmax
38 mm
Sd
0.082 m²
SPL
87.3 dB
Specifications
15″
Voice Coil Configuration
D2 Ω
15″
Qts
0.28
Re (series)
4.0 Ω
Fs
20 Hz
Cms
135 µM/N
Vas
127 lit
Mms
452 g
BL (series)
27.5tm Xmax
38 mm
Sd
0.082 m²
SPL
87.3 dB
Specifications
15″
D2 Ω
can some plug these data in to hornresp and let me know if this is a good speaker for folded horn at low feq. 25 to 35 feq
15″
Qts
0.28
Re (series)
4.0 Ω
Fs
20 Hz
Cms
135 µM/N
Vas
127 lit
Mms
452 g
BL (series)
27.5tm Xmax
38 mm
Sd
0.082 m²
SPL
87.3 dB
Specifications
15″
D2 Ω
15″
Qts
0.28
Re (series)
4.0 Ω
Fs
20 Hz
Cms
135 µM/N
Vas
127 lit
Mms
452 g
BL (series)
27.5tm Xmax
38 mm
Sd
0.082 m²
SPL
87.3 dB
Specifications
15″
D2 Ω
You do not have enough specifications. You need Qms and Qes.
Google is your friend:
QUOTE]
Agree, Though a rough estimation can be done, see the pictures:
b
QUOTE]
b
FYI, Adding once more the missing pictures , + more...
b
- Subwoofers
- Helpppppppppppppppp
