Hi guys.
i need to know whats going to last and sound the loudest : my options are : peavey eminence wharfedale real speakers Dass i would like to use them in a REAR HORN LOADED SCOOP type box. please help ! Thanks |
#2 |
Could you be more specific? Which models of each brand are you looking at?
As for be loudest, you'll need to model the drivers in some software, figure out what's what. When choosing drivers, look at efficiency before power handling. Good quality, high power amps are expensive, but low power, good quality ones are not.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
thanks! but generally which bass driver enclosure gives you the best sound? i want that chest thumping bass!
#4 |
Chest thumping comes from the 100hz~1Khz region, and how well it is integrated with the rest of the frequency range.
Candidates for the Darwin Award should not read this author. |
#5 |
I'd agree. Look for something that will go to maybe 60Hz, but keep it loud. The 60-200Hz region is where you feel it hit you in the chest. Look for a 15" woofer in a small box (usual of those small PA things) They don't go low, but they go pretty loud in the regions they can play.
#6 |
Why rear scoop horn loaded? That's fine, but what are you trying to achieve?
A horn can generate a lot of SPL, but with the driver buried inside you won't get any high frequencies. Are you playing music, or a musical instrument? More info please... |
#7 |
Where are you located i the world
Wharfedale indicates UK to me If so, why not a PrecisionDevices PDN.15BR40 has great Xmax and should give you enough SPL, and simulates very good Basicly, to get loud you need Xmax, and limited lows, and preferably a closed box to control Xmax, thus also look at driver Qts |
| Help choosing 15" bass drivers | Branwell | Multi-Way | 1 | 27th November 2003 10:37 PM |
| Good BASS drivers at partsexpress ? | goldyrathore | Multi-Way | 10 | 3rd April 2003 04:58 PM |
| Page generated in 0.08875 seconds (79.01% PHP - 20.99% MySQL) with 10 queries |
