Folks,
I'm planning to build John Krutke's (Zaph Audio) sub using the Dayton RSS315HF driver. The design can be found here (look about 1/3 down the page). I noticed that the driver comes in an 8-ohm version as well as the 4-ohm version that everybody seems to be using. Higher impedance drivers tend to be easier on the power amps, resulting in less distortion and cable loss. In light of this, is there a particular reason everybody and their dog seems to be going with the 4-ohm version? What am I missing? Thanks, ~Tom |
#2 |
Typicaly amplifiers rated for 4ohm loads are capable of a greater power output into 4ohms as they are limited by there rail voltages rather than there thermal disipation, therfore a 4ohm sub will have a greater maximum SPL with a typical amplifier.
#3 |
I am planning to drive the sub by two 125 W (into 8 ohm) amps bridged. That should give me 500 W into 8 ohms - plenty for the 8-ohm driver. But of course, I could get 250 W into 4 ohms from just one amp channel...
The data sheets for the 8-ohm version and the 4-ohm version show some subtle differences between the two. Among other things, the 4-ohm has a slightly larger excursion. ~Tom |
#4 |
Hmm the 4ohm one looks like it can play slightly lower. Although tbh the specs aren't different enough for them to be on purpose different and one suspects that this may just be one sample of each type that are actualy part of the normal distribution of the subwoofer parameters.
#5 | |
I tossed Parts Express an email. After all, they do design their own kits, so I figured they'd be knowledgeable on the subject as well. Here's their response:
The 4 ohm is mostly a matter of getting more power from the amp and being able to post higher numbers in the marketing brochures.~Tom |
| 4-ohm Speakers on 6-ohm Amp? (newbie question) | diesel_88 | Multi-Way | 23 | 25th October 2007 08:54 AM |
| How to connect 62 ohm headphone to 8 ohm output | Sunsun22 | Headphone Systems | 15 | 16th June 2007 01:29 PM |
| Single Ended Amp 8 Ohm To 4 Ohm Conversion | jsaults | Parts | 11 | 21st February 2007 01:00 PM |
| What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? | The Paulinator | Multi-Way | 9 | 11th May 2004 07:04 PM |
| Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? | Cal Weldon | Multi-Way | 16 | 21st February 2004 12:31 AM |
