Solenoid valve sub - diyAudio
Old 3rd January 2010, 11:08 PM   #1
kipman725's Avatar
Send a message via MSN to kipman725
Default Solenoid valve sub
I have been reading fan subwoofer threads and think I have an alternative for generating infra sound.
An array of high speed solenoid valves with a compesed air feed is fed a delta sigma modulated (200Hz modulation frequancy? with two sets of valves) version of the sub bass signal (3 - 20Hz).
Each set of valves is sent every other pulse such that the cycling frequancy of the valves isn't too high.
To avoid the noise of the valves been switching annoying the listener some kind of austic low pass filter would have to be used like a block of foam.
Here are some links as I am awfull at explaining things:
http://www.ittaerospace.com/pdf/solenoid_features.pdf
An Introduction to Delta Sigma Converters
Old 3rd January 2010, 11:20 PM   #2
The compressor would be kinda loud, too.
Old 3rd January 2010, 11:28 PM   #3
kipman725's Avatar
Compresor could be housed away from audio system and connected with hoses.
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
valve sub skal Tubes / Valves 0 24th September 2009 07:54 PM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 01:15 PM
valve preamp damianl Tubes / Valves 4 7th July 2006 09:42 AM
Valve Identification-Help hifileslie Tubes / Valves 21 17th April 2005 09:04 PM
Copyright 1999-2017 diyAudio
