Old 3rd January 2010, 05:27 PM   #21
Hello to everyone who try to help me out, I know that i am getting on people nerve.
Please let me explain, My grandparent have a soudsystem and a bar for many years. My grandfather pass away and the soundsystem is deteriorating so i decided to rebuild the soundsystem to keep the bar alive. In my country anyone who have a soundsystem use scoop are bass reflex, so i want to build something different something powerful and loud.
I do not know alot about bass horn and speakers so i am asking for alot of help from anyone who can help me with a good folded horn design.it is for outdoor use in open area. In one of the post someone that 18's are not good for folded horn and i must consider feq range of 30HZ and not 20HZ i am ok with thAT and other idea that will work. I was looking at some 10'' hlc ,lab12'' and selenium15'' for subhorn do not if there are good are not.if anyone can help please help
Old 3rd January 2010, 07:07 PM   #22
Speakerholic
Cal Weldon's Avatar
If you are happy with 35-40Hz as your bottom cut off (and you really should be) and a 15" or multiples of it will do and if you want it outdoors then this Selenium might be what you are looking for. Strong motor, very durable composite cone. I have 6 of these in my outdoor set-up.
It's the WPU 1507 QCF. I was trying to link to it but the PE site doesn't respond right now so try googling it later.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd January 2010, 09:37 PM   #23
for entertaining a bar crowd a lower frequency roll of @ between 30Hz and 40Hz is good enough.
Down load Danley's paper on how to design the Labhorn.
It will tell you a lot about horn design and what happens when you parallel mouths and what happens when you add extra boundaries.
A 12group of Labhorns performs flying down to 27Hz.
A 6group of Labhorns performs to spec when one boundary is adjacent to the stack. The ground gives that one boundary.
Each Labhorn is ~4feet*3.4feet*1.6feet.
Six Labhorns for ground boundary is ~3600litres (3.6cubic metres) and needs approximately 12kW with a very steep high pass filter.
Old 3rd January 2010, 10:48 PM   #24
I cant afford a 12kw amps
thing anyway
Old 4th January 2010, 12:10 AM   #25
jbell is offline jbell  United States
jbell's set of four tapped horns
I run my set of 4 horns from a single ep2500 amp. It can vibrate the bleachers on the opposite side of the football field.
For permanent install... it's just the ticket. High pass at 38hz.
If you want louder, better overall, but not quite as low... and not as big... can't go wrong with this design.
LIVE SOUND Specific Tapped Horn thread...
This post references the important post #'s.
Here's the actual cabinet design
http://www.diyaudio.com/forums/attac...dwg_rev_01.pdf
Old 4th January 2010, 05:15 AM   #26
davygrvy's Avatar
This stuff doesn't play itself! Even 30Hz at 140 doesn't come easy.
Don't forget you *are* going to need an excellent crossover, too. One that can do a deep high-pass filter to keep your drivers safe from over-excursion damage. The X-over will also need to do time alignment as 7 feet of path length need to be removed from your tops distance, too.
So budget an additional USD$400 or so for a Behringer DCX2496 or a DBX DriveRack-II.
Think out of the box
Old 4th January 2010, 03:08 PM   #27
go and download Danley's Labhorn designing paper.
It will give all the information you need to bring you up to speed on high efficiency and big SPL for your bucks.
Old 4th January 2010, 05:49 PM   #28
Speakerholic
Cal Weldon's Avatar
Parts Express site is up again. Here is the outdoor woofer I was suggesting.
Parts-Express.com:*Selenium WPU1507-SLF 15" Driver | 15" woofer 15 inch woofer midbass driver pro sound sound reinforcement PA
help with folded horn auto sub americanaki Subwoofers 24 28th January 2009 02:27 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Stroker Folded horn bhg41088 Multi-Way 12 13th February 2004 02:32 PM
DR12 folded horn strictlyhookups Multi-Way 0 14th July 2003 02:55 AM
Copyright ©1999-2013 diyAudio
