How to paint my bass speaker?
Old 31st December 2009, 10:35 AM   #1
Pigy is offline Pigy  Serbia
Question How to paint my bass speaker?
I want to colored bass speaker, because he is old and faded.
I know the method Overcoating membrane adhesive for wood in the ratio 1:1.
Can then be colored with any paint, even car paint.
I've heard that so gets tougher bass and a series of lower resonant frequency.
The only drawback is the thesis of membrane, which makes the work of suspension, and a lack of high tones.
What is your knowledge and how can I paint membrane speaker?
Old 31st December 2009, 10:42 AM   #2
osscar is offline osscar  Latvia
osscar's Avatar
I once painted an old loudspeaker membrane with black permanent marker. It succeeded well and did not affect the sound.
My DIY : http://www.tutribi.net
Old 4th January 2010, 07:18 AM   #3
Thank's Osscar,Did no one will even reply to me?
Old 4th January 2010, 09:28 AM   #4
dangus is offline dangus  Canada
With paper cones, fountain pen ink might work, and I don't think it would add any detectable weight. It should be easy to apply with a small paintbrush.
Thinned white glue (like Weldbond, or probably Lepages) made a paper cone look shiny and dark. It may have stiffened it, and probably added a little bit of weight. I did this to an orphan yard sale CTS 8" woofer for no particular reason.
Old 5th January 2010, 12:41 AM   #5
troystg is offline troystg  United States
troystg's Avatar
20 years ago I saw some 12" woofers spray painted. The dust cover, surrounds and frame were properly masked with tape before spraying.
The guy didn't measure the response before and after but we couldn't "hear" any significant difference.
Now for the reason. He was young and wanted them to look like boobs so he painted them "ti77y Pink". Ah the good old days of ignorant youth. I laughed although I would have never had the guts to do that myself.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 5th January 2010, 12:51 AM   #6
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
I do this all the time with paper cones (using modpodge as i feel it remains a bit more flexible than wood glue PVA formulations). If i want colour i use food colouring. Black is a bit trickier. Black inks are actually blue, so i usually use that in conjunction with a bit of black acyilic paint.
Speaker Tweeks -- Puzzlecoat & Ductseal
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th January 2010, 08:08 AM   #7
Thanks friends!
The goal, why would it painted because it would thus get the look beautiful cones.
Second, because it would thus old received solid cones means in some way would reparationI.
I know it will be harder for the cones, and this applies exclusively to the cones of the paper.
Experiences of other say that the best fairy tale with black paint (coating means wood).
Others dissolve glue for wood and water in the ratio 1:1.
Then paint another color, and it seemed to be beautiful.
And the sound is firmly-stronger.
Cao!
Old 5th January 2010, 01:06 PM   #8
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Tip for black ink, tattoo ink would be black without the blue hue etc.. I think for all colors,tattoo ink may be a better alternative than normal pen ink in the long run etc..
http://www.pricksofthetrade.com/tatt...g-ink-1oz.html
http://www.pricksofthetrade.com/tatt...sun-black.html
Old 6th January 2010, 07:56 AM   #9
To a great idea.
Visaton has such a tool to repair paper cone, black in color.
The advantage of proceeding with wood glue and then paint is that the paper cone becomes stronger-rigid, then the paint can be any color and say either.
Signs and car paint can, the only disadvantage of this procedure as paper cone becomes the thesis and speaker can no longer so high to play and speaker becomes less sensitive.
Say this because most of the cone are aging time, have lost elasticity, and the question is what color tattoo will be given evenly applied to the cone, or may remain colorful cone, means perhaps would have patches, and it would be ugly.
Thanks for the tip!
Old 28th January 2010, 09:55 PM   #10
Village Plank is offline Village Plank  United Kingdom
Village Plank's Avatar
What worked well for me was liquid black shoe shine in a bottle with the foam pad (cherry blossom brand). Application was quick and easy.
How to paint my bass speaker?Hide this!Advertise here!
bass speaker help tobee1 Instruments and Amps 547 18th March 2014 10:56 AM
is Warnex textured speaker cabinet paint good? pikcellmix Multi-Way 2 25th November 2010 06:42 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 02:14 AM
Stuff to paint on speaker cones ?? andrew01 Multi-Way 82 28th May 2005 10:55 PM
Best way to paint speaker grills robgar Multi-Way 2 8th June 2004 12:21 AM
Copyright ©1999-2017 diyAudio
