#11 |
Most paper coned speakers will allow atmospheric pressure equilisation anyway.
Someone on here advised drilling a hole, then putting felt over it.
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes ------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns |
#12 |
Adire Audio had a formula for calculating driver sag. It can still be found in the wayback machine archives: http://web.archive.org/web/200510141...rientation.pdf
Hope this helps. |
#13 |
#14 | |
That's the take-home message I got out of this... ~Tom |
#15 |
Speakerholic
I respectfully disagree.
The take home message should be that no driver is airtight and that this whole thread is a moot point. You should not consider drilling a hole or leaving any sort of leak in your cabinet, you should strive to make it as airtight as possible. Many other materials such as curved glass window units for solariums do have to deal with this when shipping by air, hence the bleeder tubes. Not speakers. |
#16 |
Atmospheric pressure changes are not large and rapid enough in a fixed locale to outweigh the inherent leak through the driver. If they are, then your local weather concerns are of far greater importance than critical listening.
Unless your speaker is capable of holding a vacuum (it ain't), there will be leakage no matter what pains you go through to seal it. I consider a closed box well-sealed when the cone feels stiff and takes a second or so to return to center after pressing the cone in. This may require sealing terminals, too. If it makes you feel better, then drill a hole. I put too much work in my boxes to drill into them unnecessarily. (edit) sorry Cal, your post wasn't there when I began to reply.
Tim |
#17 |
Speakerholic
Actually I should clarify with something I just read. When shipping by air, this may be necessary as it was with one model of BeoLab speakers. I believe it had to do with the quick pressure differential that, as tsmith says, is near impossible on solid ground.
| Possible Vent Hole Issues? | timstupid22 | Construction Tips | 0 | 27th September 2009 11:24 PM |
| My sealed timber subs. | Foxx510 | Subwoofers | 12 | 28th March 2008 04:57 PM |
| Best subs for small Sealed enclosures | Dwn2rth | Car Audio | 0 | 18th May 2007 07:49 PM |
| Considering sealed vs vented for my AV12 subs | paulspencer | Subwoofers | 44 | 15th December 2004 01:07 PM |
| Vent hole trim? | CrisTUFR | Multi-Way | 6 | 21st July 2004 12:03 AM |
| Page generated in 0.09298 seconds (76.65% PHP - 23.35% MySQL) with 10 queries |
