Subwoofer recone
Subwoofer recone
Old 28th December 2009, 10:55 PM   #1
icecoolwas is offline icecoolwas  United Kingdom
Default Subwoofer recone
Hello, I have a Infinity Reference 1250W (Model #) Subwoofer, one of these.
And well, Basically this morning my brother accidentally blew it while he took my car out. It was my fault since I had a new amp and didn't lower the gain down lower than the input signal was (the amp gives out 500wrms @ 4ohm and the sub only takes 300wrms). So I took it out the box, and wanted to confirm it was blown, I used glue removing gel and carefully removed the cone and the surround and yeah, the coil was burned.
What I was wondering if it is possible to recone, or recoil the subwoofer? I mean its in perfect condition apart from the coil and don't want to throw it away (No warrenty left either). If there is no recone kit, is it possible to remove and replace the coil with one I could make myself? this subwoofer is a SVC sub. Just wondering what kind of options I have and if anyone knows what I would have to do.
Thanks.
Old 29th December 2009, 11:45 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
At £55 each, you should probably just get a new one...
Recone kits are never cheap (usually more than 1/2 the cost of the speaker), so you're probably better getting a new one. If you wish to do it for experience, then you can probably contact the manufacturer and see how much the kits are.
My work: www.grimshawaudio.com
Old 29th December 2009, 11:47 AM   #3
I was thinking about getting a new one but since I've taken the cone off and seen the mechanics behind this thing it doesn't seem very hard to repair once I obtain the part. I'll guess I'll contact Infinity and see if they do sell repair kits.
Thanks.
Old 29th December 2009, 04:47 PM   #4
Cokewithlime is offline Cokewithlime  Canada
FYI - a recone kit does not include a new coil or spider.
If you say that you have burned out the coil then you will also have to replace these parts as well - not cheap and not a simple task to do without factory alignment jigs. I think you are going to find that both time and money wise it will be just more efficient to purchase a replacement driver.....
Old 29th December 2009, 05:00 PM   #5
John Sheerin is offline John Sheerin  United States
Actually recone kits typically do include a new coil and spider along with a cone and dust cap. You could refoam a driver which is just a surround edge, but that's not the same thing.
I'd try to track down a kit through the Infinity service department. I know they have one - I bought a plate amp from them a few years ago. However I know they usually won't sell JBL Pro recone kits to anybody but dealers, for example, as it takes some skill to put them in (and Harman owns both JBL and Infinity, so it might be a common policy).
Old 29th December 2009, 05:07 PM   #6
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I highly doubt they stock drop-in recone kits for that sub. In that market, if someone blows one, they'll just go back to Best Buy and get another Coil diameters and lengths are often non-standard, as well.
You're right, the repair isn't very difficult (beyond making sure the coil is properly shimmed in the gap)...but it's not very practical here.
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 29th December 2009, 06:29 PM   #7
chris661's Avatar
I suppose you could try to get hold of something that will go in, for the experience. Measure up the voice coil, spider etc, see what will drop in.
Be warned - you'll probably want to get another one aswell - unless the correct kit is used, results are unpredictable at best.
Subwoofer reconeHide this!Advertise here!
Speaker recone in the UK c0nfu33io Multi-Way 5 17th July 2009 11:43 PM
Recone for a Peerless 830491 XLS8? kappa546 Multi-Way 3 17th October 2008 05:04 PM
Dynaudio speaker Recone garyroach Multi-Way 5 17th April 2008 03:38 PM
Vintage Gibson recone DeadSpeaker Multi-Way 0 30th January 2008 11:53 PM
Recone an anon 15"? Pbassred Multi-Way 4 25th March 2005 02:07 AM
