Old 27th December 2009, 03:00 PM   #1
Default DIY Budget Sub
I have a JL Audio car sub that I no longer use and it is in a sealed box that is slightly larger than JL audio recommends.
JL audio recommends an 18"X11"X10.25" \
My box 15"X15"X11" / exterior dimensions 3/4'' mdf
I would like to add it to a budget bookshelf system for music only using the Best Buy Insignia NS B2111 that I am building for fun. I will eventually build some DIY bookshelves.
My JL Audio sub is a 10W0-4. 10" 4 ohm budget sub
Fs 24.2
Qes 0.420
Qms 8.560
Qts. 2.45 ft3 or 69.4 litres
Xmax 8.6mm or .340"
efficiency 85.5db
power handling (continuous) 125 watts
I have been looking at some Parts Express plate amps, Do you have any other budget plate amp suggestions?
Do you think I should build a ported enclosure or stick with the sealed? I am a home builder so I have all the necessary tools.
Thanks for any suggestions and help.
Scott
Old 27th December 2009, 04:48 PM   #2
Mikey p is offline Mikey p  Canada
You would get a lot more output out of the sub in a ported enclosure 2.5 cu.ft tuned to 26 hz with a 4" flared port 17" long. Either sealed or ported, a 100 watt Dayton amp would be all you'll need.
Parts-Express.com:*Dayton SA100 100W Subwoofer Amplifier | subwoofer amplifier subwoofer amp sub amplifier sub amp plate amp DayAudSubAmp050109
Old 27th December 2009, 06:07 PM   #3
You could also pick up one of Jack Hidley's surplus Foster WF-100K amps.
NHT drivers and electronics surplus sale
Essentially the same wattage, considerably cheaper.
Old 27th December 2009, 11:23 PM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi, Good suggestions!Maybe this folded T-TQWT is suitable too:
b
Old 28th December 2009, 12:12 AM   #5
badman is offline badman  United States
Custom Title
badman's Avatar
Hey, realistic car specs! Those are a rarity indeed!
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 28th December 2009, 12:17 PM   #6
It should be also mentioned that this amp has a Hi-Pass filter at 29 hz that would need to be modified for this application.
Old 28th December 2009, 06:41 PM   #7
True, I believe that is also the case with the Dayton, but no documentation is available. In the case of the Foster, considerable details and instructions are provided, as well as a spreadsheet to calculate the appropriate values of resistors.
Old 29th December 2009, 03:41 PM   #8
I am using the exact same subwoofer in my home audio setup. I have tried both sealed and bass reflex enclosures. The sealed enclosure sounds really tight and articulate, but lacks the 20-30hz extension the bass reflex enclosure had. Both types left me wanting. I think a bass reflex design is the most practical, mostly because of the lower extension. I think I may try a transmission line or a folded horn next.
Old 29th December 2009, 11:25 PM   #9
HiVi Guy,
What are you powering it with and what are you trying to accomplish with a folded horn or transmission line?
I am looking to do this for the low end for a budget 2.1 music system (for fun) using bookshelf speakers.
Scott
Old 30th December 2009, 04:55 PM   #10
The NHT plate amp looks like a good deal. The only thing I don't like is the spring clip speaker level connectors. However the Dayton plate amp is out of stock until @ 2/20/10 which is quite a ways off.
Scott
DIY budget Super Tweeters davidhugo Multi-Way 11 2nd April 2009 11:48 AM
Budget DIY, I tried searching Luke352 Multi-Way 12 22nd July 2006 03:12 PM
budget diy bookshelves and sub uzziah Multi-Way 2 1st March 2005 08:24 PM
Help with my budget sub diy vegeotto Subwoofers 2 24th January 2004 04:21 AM
is there a budget diy design for me? leadbelly Multi-Way 7 20th January 2003 02:09 AM
Page generated in 0.11752 seconds (78.24% PHP - 21.76% MySQL) with 11 queries
