Hello! im pretty new here and this is my first post. Anyhow, im werry new to sound, and i got some old speakers from a friend to expriment on.
i have tryed to build a box now, a 116l big and 30Hz is the port on. But well i doesnt sound like i whant to ![]() So i wonder if some1 whit more experiens like to calculate a box for me? I want to use it for indoor usage. And ye, i got 2 drivers so i can use Isobark, if it works? Here is the parameters: Pyle Pro series II 15" Code:
PW15100/4 FS-34HZ QMS-7.98 QES-.41 QTS-.39 VAS-6.37 CU FT XMAX-.30 IN VD-39.8 CU IN ZMIN-3.2 OHMS RE-2.8 OHMS SPL-94 DB |
#2 | |
What exactly is it you don't like about the sound?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley |
#3 |
Well i think i build it wrong, Just like some advice on how you wold calculat it, See if i calculated rigt and so. Just an experties adivce
If someone got 5min to calculat it for me..Thanks alot! //Simon |
#4 |
hi there
to calculate a box you have two options: google all the formulas and calculate, or... get a program to do it for you. you put all the parameters of the woofers in the program, and it tells you how your box should be built. try WinISD, it's free and it's simple what makes it a good starting point. Usually simpler things in paper delivers simple models to construct. hope to have helped. cheers gaston_pdu |
| Ported box for TAD Tl 1603 ? Calculation help | matsj | Subwoofers | 26 | 24th December 2009 07:32 PM |
| subwoofer, box calculation | jankappel | Subwoofers | 9 | 9th November 2006 08:28 PM |
| Box size Calculation-Help | NickC | Multi-Way | 6 | 23rd March 2006 10:04 PM |
| need advice on box for a xls12 sub | shannow | Subwoofers | 39 | 26th October 2004 01:54 AM |
| Box volume calculation questions. | Nappylady | Subwoofers | 2 | 29th March 2004 09:03 AM |
