30hz 10" tapped horn magic?
Old 27th December 2009, 02:20 AM   #1
killerfishes is offline killerfishes  United States
Send a message via AIM to killerfishes
Default 30hz 10" tapped horn magic?
just did a quick hornresp. what do you think for my music room?
Type : Davis 25 SCA 10W
Impedance (Ohm) : 6 ohm
Sensitivity (dB) : 92
Fs : 28 Hz
Re : 5.96 ohm
Res : 34.32 ohm
Qms : 2.23
Qes : 0.39
Qts : 0.33
BL : 10.08
Xmax : 4 mm
Cms : 712 μm/N
Mms : 30.9 g
Vas : 109 L
Sd : 330 sq. cm.
Le : 0.53 mH
see attachment
Old 27th December 2009, 02:26 AM   #2
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
If you filter stiff over 100Hz it should be fine. How big is that thing ?
Old 27th December 2009, 02:49 AM   #3
9.5ft long
3.69 cu.foot system volume
fold it and should not be too bad. I just don't know about the 4mm x-max. at 40hz and 2 watts is showing about 3.7 mm @106dB
Edit. with room loading my dual horns play to a 74hz F3
Old 27th December 2009, 03:11 AM   #4
There was a horn in the 60th that i build in the 70th called "Schmacks Horn" that also got down to 30Hz and was not extremely big. It sounded great as far as i remember and i plan to build one again soon. I whould like to show my son what we did in hippy time.
I build that horn from soft chipboard with the kitchen knife of my mother. I stated at noon and at 8PM i had it ready for party on that day. We called that BEAT Abend.
Old 27th December 2009, 03:28 AM   #5
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
I have seen that plan of the Schmacks Horn ,as far I can remember it was suggested for large 12" drivers with stiff suspension . Nowadays with the availability of long-throw and power angry subs together with high power plate amps ,the size could be reduced to a fourth .
Old 27th December 2009, 03:36 AM   #6
no, it was an 8 " wideband driver. you can find the plans on the web or i can look for you.
Old 27th December 2009, 03:38 AM   #7
here it is Ein Hornprojekt nach Schmacks
Old 27th December 2009, 03:58 AM   #8
Thanks ,Joachim...I had been vague but those horn designs have been very inspirational to me some years ago . I was saying that fashion changed a little from 30 years and now I would expect the same impact from a little 2 way box . Not to talk of subs ,where power and heat demands (of the magnets) has to be considered.
Old 27th December 2009, 04:27 AM   #9
yes, i am also listening to conventional boxes but because of my MPP thread where i whould like to design a total sytem i was interested in high sensitivity again. i think designs like this horn or dipols are ideal for DIY. they are hard to get in good quality comercially and when they are very expensive because of the woodwork and the expensive drivers.
Old 27th December 2009, 05:15 AM   #10
Oooh ! I see ...just took a quick glimpse at the beginning of the thread ,then forgot it.
Now just skipped some (technical) pages and watched the PDF at lastretty obscure !
Could it be more hidden ?!?
I feel safer with your words ,those are the same feelings I have towards DIY.
30hz 10" tapped horn magic?Hide this!Advertise here!
Dual 8" tapped horn = TH-SPUD geitmans Subwoofers 152 23rd April 2016 08:51 PM
Dayton Classic 18" DCS-450 - Tapped Horn? dolinux Subwoofers 15 4th December 2009 04:38 AM
Tapped Horn for 18" bass angeloitacare Subwoofers 14 28th March 2009 07:37 AM
Another tapped "horn" ? phase_accurate Subwoofers 16 11th August 2007 08:05 AM
