Infra infrabass for 400 square meters: How? - Page 2 - diyAudio
Old 17th December 2009, 06:25 PM   #11
Speakerholic
Cal Weldon's Avatar
Originally Posted by myhrrhleine View Post
do keep in mind that the intestines are inclined to let go at around 8hz
Wives tale.
planet10 needs your help:
Let's help Ruth and Dave
Old 17th December 2009, 07:53 PM   #12
davygrvy's Avatar
Just cause those mythbuster folks couldn't prove it, doesn't mean they're right.
Think out of the box
Old 17th December 2009, 08:42 PM   #13
re:'Just cause those mythbuster folks couldn't prove it, doesn't mean they're right' - actually, it does, Science works by repeating an experiment & seeing whether the result confim the hypothesis or not. OK, you may quibble about the rigour of their 'experiments', but the only effective rebuttle is to produce evidence to the contrary... the lack of this confirms Cal's hypothesis...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 17th December 2009, 10:06 PM   #14
davygrvy's Avatar
but the lack of a positive doesn't make a negative. Disco dumps are well documented. Extreme VLF sure makes me queasy and sick.. Add a pouding beat, which the myth guys DID NOT DO, and watch. Or maybe tightly banded VLF noise..
Yes, I very much disagree with the testing they did for the brown note.
Old 18th December 2009, 12:16 AM   #15
Speakerholic
Cal Weldon's Avatar
And you think that has something to do with the music?
Sure it does, it's jiggling up what you had to drink.
Me too. I wanted to see the **** hit the fan, so to speak.
You remember they used ported 18" PA woofers and then fooled around with port plugs (bungs)
Old 18th December 2009, 10:51 AM   #16
I would like to see Tom Danley test the Brown note phenomena!
A bunch of ported 2x18 will not produce 145 dB @ 8 Hz.
I can see some big shipping containers loaded with Fs =15 Hz Qts= 0.4 high Xmax drivers in a tapped horn. 4 of those stacked should do it, if its doable.
We live in a horizontal world, why use vertical topologies???
Old 18th December 2009, 05:10 PM   #17
davygrvy's Avatar
Okay, I get it... I wasn't aware that cocaine makes you poop.
Old 18th December 2009, 07:51 PM   #18
Speakerholic
Cal Weldon's Avatar
Cocaine, crystal meth, ecstasy, mushrooms, LSD, bennies, morphine, heroin, ketamine...
Take your pick.
Old 21st December 2009, 04:51 PM   #19
I always thought heroin makes one constipated.
Old 21st December 2009, 04:59 PM   #20
Speakerholic
Cal Weldon's Avatar
Sorry, no experience. I was really just listing drugs that have been known to frequent discos. I thought that since there are many recorded instances of persons doing the disco dump when simply in anticipation of doing heroin that maybe...
Graham Holliman Velocity Coupled Infra Bass Speaker? Neopsp Subwoofers 412 29th July 2013 02:49 AM
any 1 eva tryed using 'phones + sub for infra? Helix Everything Else 5 7th July 2011 11:13 PM
VU Meters Weston Tubes / Valves 15 3rd August 2008 12:45 AM
infra-red detectors pfcs49 Parts 6 7th March 2008 04:07 AM
Remote control fo creative infra 18X ?? hannes86 Digital Source 2 12th November 2004 05:14 AM
Copyright ©1999-2017 diyAudio
