Infra infrabass for 400 square meters: How?
Old 21st December 2009, 08:11 PM   #21
davygrvy is offline davygrvy  United States
davygrvy's Avatar
I like that shaker device idea. Types for concrete already exist in many forms. I remember when my street got repaved. The roller did such a good job making what felt like a 1.5 earthquake at 15 Hz it broke a water main joint at the intersection.
Think out of the box
Old 22nd December 2009, 12:24 AM   #22
Don Hills is offline Don Hills  New Zealand
At Sun City, in South Africa, there is a "Lost World" area. Part of it is crossed via a large bridge mounted on flexible supports. Periodically it simulates an earthquake. The bridge shakes horizontally at 2 or 3 Hz, courtesy of motor driven drivers - you can feel them spin up and slow down. At the same time, LF rumblings are generated by big subs mounted in concealed enclosures along the sides of the bridge. Finally, higher frequency components are provided by stacks of JBL cabinets in imitation caves near the bridge.
If I were going to generate "infrabass" acoustically, I'd use multiple large high excursion drivers in enclosures with a sharply peaked resonance at, say, 8 Hz. So rather than a smooth response, they would have an "organ pipe" resonance. Feeding them with LF noise rather than a steady tone would produce a quasi-earthquake effect.
Old 22nd December 2009, 11:19 AM   #23
Andreas is offline Andreas  Denmark
The most violent infrabass I have experienced was made by a crane mounted machine that vibrated iron plates into soil for building foundations. the individual plates where 6 m long x1 m wide and probably 10-15mm thick Effectively it made the whole adjacent concrete building vibrate to an extent where I hade a 12kg heavy balance dancing around on the table.
I cannot find the english word for the contraption but here is a picture.
http://www.arkil.dk/Default.aspx?ID=273
Andreas
Old 27th December 2009, 01:28 AM   #24
Ron E is offline Ron E  United States
Ron E's Avatar
Vibrationsteknik
Pile Driver
Pile driver - Wikipedia, the free encyclopedia
These are used to reduce noise, otherwise they often use a device that runs on fuel and is basically a 2-cycle "reaction engine" that slides on a rod that has a piston attached to it, when combustion occurs, it throws the "engine" up again. Every explosion drives the pile in a bit further.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Infra infrabass for 400 square meters: How?Hide this!Advertise here!
Graham Holliman Velocity Coupled Infra Bass Speaker? Neopsp Subwoofers 422 15th July 2017 10:04 PM
any 1 eva tryed using 'phones + sub for infra? Helix Everything Else 5 8th July 2011 12:13 AM
VU Meters Weston Tubes / Valves 15 3rd August 2008 01:45 AM
infra-red detectors pfcs49 Parts 6 7th March 2008 05:07 AM
Remote control fo creative infra 18X ?? hannes86 Digital Source 2 12th November 2004 06:14 AM
Copyright ©1999-2017 diyAudio
