Old 18th December 2009, 09:01 AM   #11
djk is offline djk
djk's Avatar
This box looks pretty good for a pair of JBL 2225H. It's an EQ'd 6th order design, tuned to 31hz. The general layout is:
Here is the performance with the original driver I designed it for:
It is 100.4dB/2V/1M (1W), 128.2dB at full power (600W). 3dB down at about 29hz. The JBL driver has about 2.3dB less maximum output in the 50hz~60hz region due to its higher Fs and its lower Vas and x-max.
Candidates for the Darwin Award should not read this author.
Old 22nd December 2009, 05:14 AM   #12
tomp787 is offline tomp787  United States
Default 4685 box guess
Here is some simulation data based on the box dimensions. It was done by Zilch and posted on Audioheritage.
Old 2nd January 2010, 01:02 AM   #13
what driver did you design those boxes for ???
Old 2nd January 2010, 02:24 AM   #14
djk is offline djk
djk's Avatar
I had a driver custom made for them, the part number Eminence assigned the design was 15711.
The simulation is of another custom Eminence driver, sold by Martinsoundpro.com. Their part number is #1844.
It is also possible to use some 18" drivers in this design, it just depends on the T/S parameters.
Of course the size may be adjusted for almost any driver with a Qts around 0.312, the cut-off will be around Fs, and the size about 0.41x the Vas.
Old 2nd January 2010, 08:08 PM   #15
it may appear, you are correct, i just downloaded a real time analyzer, (Software) it has a tone generator and oscillascope, anyways i was using the tone generator, and listening to 30hz and i didnt realize how low that was. my yamaha 10
' subs were chuffin and not liking be called upon to reproduce that
Originally Posted by Brett View Post
I agree with Ron for a couple of reasons. First of all he is correct re our brains filling in the fundamentals. Next, go and measure some: even on a 34" scale 4 string the fundamental on most low E is much lower than the 2H. On a B it is even worse as the strings aren't long enough to support it.
Have you ever had 30Hz loud on stage (presume you want this for at least some live work)? It's very annoying and can cause all sorts of resonances and muddy the sound.
Also consider many of the popular BG rigs such as Ampeg 4 and 8x10 dive below 70Hz and yet are often described as having good fundamental tone. For recording direct with maybe some micced cab mixed usually in sounds best.
Old 16th March 2011, 05:21 PM   #16
Question did somebody build JBL 4685 COPY?????
I'm planning to build copy of JBL 4685 with 2 x JBL 2225h, please help about enclosure design.
Old 16th March 2011, 09:34 PM   #17
epa is offline epa  Netherlands
FYI
low B (B0)is 30.87 hz .
on the left a sine wave 31 hz,on the right a snapshot of music with 31 hz bas(see the harmonics )
Loudness Control Calc - Help Please LinuksGuru Tubes / Valves 0 14th December 2008 04:43 PM
Where is the error with this ohm's law calc? riotubes Parts 19 24th November 2006 06:33 PM
winisd and air velocity calc ALFIrE Multi-Way 9 12th October 2004 09:34 AM
FS: pair of JBL 2225H 15" $300 spitz Swap Meet 0 16th June 2004 06:28 PM
TI-Calc speaker building Yoda Multi-Way 1 16th April 2002 01:44 AM
Page generated in 0.09231 seconds (78.48% PHP - 21.52% MySQL) with 11 queries
