Old 16th December 2009, 12:49 AM   #1
form109 is offline form109  United States
Default Sony SA-W303 Subwoofer
Purchased one at a Flea Market for 15 Bucks.
Pics can be found below in the links.
Sony SA-W303 Active Super Woofer Sub - My Photo Gallery
photos are linked here since the image insertion in the Post doesnt seem to work too well for me...nevertheless enjoy.
Old 16th December 2009, 01:11 PM   #2
Marsh is offline Marsh  United Kingdom
You were robbed.
I learn something old every day.
Old 16th December 2009, 02:47 PM   #3
you could have gotten some beers for this, bad investment
Old 16th December 2009, 03:48 PM   #4
chris661's Avatar
It's got an amp, and some interesting controls. I wouldn't say you've been robbed, but your money may well ave been better spent.
I've always been curious about those little, low and rumbly subs - what sort of driver do they use?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 16th December 2009, 07:01 PM   #5
its Not a Bad Sub,its a good Value to me...the Bass Peaks somewhere around 40 and isnt Signifigant Below 33...it sounds good.
The Driver is a 6.5" Paper Cone with a Rubber Surround,Flat Dustcap,its Bigger than it looks in the Photos and Quite Heavy.
The Enclosure is Ported...which sony Refers to as "Acoustically Loaded"
the Port Moves alot of Air around 40 Hz,Below the Tuning Frequency the Woofer Unloads abit below 33 Hz.
Old 16th December 2009, 07:04 PM   #6
LOL im 15...no Alcohol Here
Old 16th December 2009, 10:50 PM   #7
turns out the Sub is Not Properly Tuned as are most Commercial Subs,if the Port was Designed a little Better the sub would have a Higher Value(Retail)..its still not a bad sub though.
Old 17th December 2009, 04:47 AM   #8
Explain?
Old 17th December 2009, 05:02 AM   #9
Originally Posted by Brian Steele View Post
Explain?
i should have reworded that to make it Clearer...what i ment to say is the sub isnt Properly Tuned in a Sense...its tuned in the 40's and comparing it to a larger sub i thought it should have been tuned a little lower....the main problem is the Port....its simply too big and i dont believe its Flared so it makes terrible wind noises when pushed Very Hard.
The Sub Meets my Needs though.
i was just thinking how much better this sub,and most other commercial subs would sound if the manufacturer Took more time to Optimize the Sound rather than just throwing a Random Driver in a Random Box.
Old 17th December 2009, 06:29 AM   #10
chris661's Avatar
I'm same age. Neat.
Sony CDP-337ESD v Sony CDP-X33ES which is best? eldarvanyar Digital Source 0 10th January 2008 11:04 AM
Need help with Sony SA-WX700 subwoofer drivers... chops Subwoofers 18 6th September 2007 03:05 PM
Sony XS-L1290P5 Subwoofer Box chevelle2720 Car Audio 6 26th December 2003 03:10 AM
Copyright ©1999-2013 diyAudio
