4" Woofer from Colby Speaker System - diyAudio
Old 15th December 2009, 10:13 PM   #1
form109 is offline form109  United States
Default 4" Woofer from Colby Speaker System
i went to the Flea Market today and Got a Colby Speaker system...well the woofer to it anyway...to my Dismay the Sub Didnt even power on when it was plugged in...i returned the sub..and traded it in for another one Which ill post later...anyway i got to keep the Driver in the sub.
http://www.flickr.com/photos/general...47732/sizes/o/
i guess you couldnt really call this a Subwoofer...its awfully tiny...but it does have a good amount of Excursion..and doesnt make alot of noise when its moving,the Unit has a 20 Watt 4 Ohm Rating...the Main Thing i noticed though is the Rubber Surround.
http://www.flickr.com/photos/general...n/photostream/
anybody have any suggestions what to do with this thing?
Old 16th December 2009, 03:52 PM   #2
chris661's Avatar
These images don't work for me. If you had a woofer tester, we could suggest some interesting applications for it.
Alternatively, small woofers like those, in my experience, do better when the port is blocked (I use socks), or sealed completely.
My work: www.grimshawaudio.com
Old 16th December 2009, 03:53 PM   #3
MaVo is offline MaVo  Germany
I cant see the pictures, but since 4 inch is probably even to small for a midrange, i doubt you can get usefull amounts of bass out of that. maybe you could build a small computer fullrange speaker out of it.
Old 16th December 2009, 06:00 PM   #4
Speakerholic
Cal Weldon's Avatar
MaVo,
You are right but what's the point? He asking for assistance with what he has.
I can't open the attachments either.
Go down to Manage Attachments, then Browse, attach your file then hit Upload. When they show up, close the window and hit Submit Reply
File Type: png Screen shot 2009-12-16 at 10.56.59 AM.png (127.7 KB, 191 views)
File Type: png Screen shot 2009-12-16 at 10.57.10 AM.png (111.1 KB, 183 views)
planet10 needs your help:
Let's help Ruth and Dave
Old 16th December 2009, 06:44 PM   #5
Moondog55's Avatar
Small bandpass box, I have a similar driver here that is doing nothing.
Surprising amount of bass for the woofer size, from memory 4liter back section 2 liter front section and a port about 50 * 70mm.
My nephew blew his amp and the woofer has been sitting here waiting for a project
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 16th December 2009, 06:50 PM   #6
frugal-phile(tm)
planet10's Avatar
The URLs linked are not images, they are FLikr web pages (and they each had an error in them). I've fixed them so you can see.
Just a wild guess, but if these have been optimized for woofer duty, you can likely get into the 50s with them, maybe a bit lower, but with efficiency in the low 80s or high 70s.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th December 2009, 07:57 AM   #7
chris661's Avatar
It looks pretty typical of small sub drivers. Here's an idea - make it into a small ipod dock, ie, put the woofer on the back/bottom, and add a couple of small full-rangers.
Old 18th December 2009, 11:15 AM   #8
Originally Posted by Cal Weldon View Post
MaVo,
My intend was to give a little perspective.
If one really wanted to get the most out of it, i can only think of two options. Either you maximise its output by minimizing the losses it has on the way to the listener - which means you put the sub next to your head (i have done so too in the past, it can work, for example behind the head if you sit on a couch) or you maximise its output by using a horn which amplifies the output the speaker has. You could make a cute tapped horn from it and if your room is small and your listening habits are more on the moderate side, it could be a fun project. If you dont expect too much low bass, it could make a interesting midbass horn
Old 24th December 2009, 05:21 PM   #9
i mistaked the size...its actually 3"...it has a Pretty Wide Range...i think it would be most Useful as a Fullrange than a woofer...though a Few of them with a nice Tweeter would make nice Surrounds or a Center channel.
Old 24th December 2009, 06:31 PM   #10
chris661's Avatar
A lot of 2.0 PC speakers use such a thing, with a tweeter, crossed at 8kHz ish. The extra tweeter, in my opinion isn't always necessary.
Good luck in whatever you decide to do with it.
3-way + sub woofer near field "mid" to HI-FI PC speaker system firefart_1st Multi-Way 2 9th September 2008 11:07 PM
Portable Speaker System "Zen Visionary" with Sonic T Amp Xspunge Class D 7 14th October 2006 08:25 PM
the &quot;ibox&quot; custom ipod speaker system-PLEASE HELP oddjob7 Multi-Way 9 27th January 2006 11:41 PM
2-way System using an 8" woofer??? nrgy Multi-Way 12 11th July 2005 06:34 PM
Anyone design a system with the Dynavox 28mm tweet and 6.5" woofer? JCoffey Multi-Way 0 21st April 2005 02:26 PM
Copyright 1999-2017 diyAudio
