Sealed 15 to Compliment Sachikos
Old 8th December 2009, 01:45 AM   #1
GusGus111 is offline GusGus111  United States
GusGus111's Avatar
Default Sealed 15 to Compliment Sachikos
Guys,
I've been wandering the forums for a couple of weeks now trying to decide on a subwoofer design and plan that satisfies what I want. Some months ago I built a pair of Sachikos and really love them. I'm inexperienced when it comes to speaker quality, having not listened to many different kinds of speakers before. However, the quality of the Sachikos is just great. If only some of my buddies appreciated it as much as I do...
Now I want to add a subwoofer and have mostly decided on a sealed 15" using the Dayton DVC driver. In the future I would love to build the Tuba HT and would like to reuse the driver at that time.
What I want is something that fits the Sachiko's audible qualities and is not huge (yeah, I know what you're thinking). One set of huge speakers is enough right now. I plan to use it mostly for home theater and some music types (I listen to almost all genres). If you have other suggestions I would like to hear them.
Thanks, and I hope this thread can help someone else out as well.
Gus
Old 8th December 2009, 02:42 AM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
How high does the Dayton go?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th December 2009, 02:49 AM   #3
GusGus111's Avatar
The usable frequency range on the Dayton is 20-450 Hz.
Old 8th December 2009, 03:28 AM   #4
frugal-phile(tm)
planet10's Avatar
450 might be high enuff, Did you consider 2 woofers instead of 2 voice coils?
dave
Old 8th December 2009, 03:37 AM   #5
GusGus111's Avatar
No, I haven't. What would be the advantage with that option? Would it require two enclosures? I enjoy learning the details of the different designs, so if you would please... Thanks!
Old 8th December 2009, 04:16 AM   #6
frugal-phile(tm)
planet10's Avatar
If you follow Geddes or Toole, they recommend at least 2 woofers. Careful placement can actively cancel room modes.
As well, one would guess, that 2 woofers would likely be 2x12 or 2x10 instead of 1x15. The smaller drivers should reach up higher which is a good thing when trying to integrate with a FR.
My next woofer project is a pair of push-push 8"
dave
Old 8th December 2009, 02:05 PM   #7
Bluto is offline Bluto  United States
Dave -
What are you planning for your push push 8's?
I keep looking at your design at Apex Jr. for some TB long throw 8's I have . I'd like to build 2 of them but have space constraints.
Old 8th December 2009, 08:05 PM   #8
frugal-phile(tm)
planet10's Avatar
Sealed CSS Trio8... skinny width -- Just enuff to fit a holey brace in between the magnets, tallish, and as deep as needed.
dave
Old 1st April 2010, 08:07 PM   #9
GusGus111's Avatar
So after a few months of contemplation, I am now considering a push-push design using 2 Dayton 12" woofers instead of the single sealed 15. Below is the URL for the driver in mind:
Parts-Express.comayton SD315-88 12" Shielded DVC Subwoofer | subwoofer sd315-88 12" subwoofer dvc dual voice coil dayton subwoofer dayton dvc dayton 12" woofer daytonDVC030209 Upto15PerOffDASubs
I chose it because of the high extension to integrate better with my FR's and the relatively cheap cost. I plan to use the sub for music (that needs it), but mostly HT.
My questions are:
1. Will this design fit well sonically with my Sachiko cabinets (tight and clean), or what might be better? I have somewhat limited space and the sub will be in a long, fairly narrow room with normal ceilings.
2. Is there a better driver for this setup that fits in my price range (<$80 apiece).
3. When designing the cabinet, do I just double the volume compared to a single sealed cab for the same driver? Also, does a square or perhaps slightly taller cab work as well as anything else?
I'm planning on the wiring the DVC of the above driver as such (top image):
I want to do this right, of course, so I do appreciate your comments.
Sealed 15 to Compliment SachikosHide this!Advertise here!
Wilson duette driver compliment Hastur Multi-Way 50 26th May 2012 06:47 PM
6.5, 8", Chang, Sachikos? Xmas project Bob, W7ETA Full Range 24 28th November 2009 07:15 AM
Sub to Compliment mFonkens st_eloi Subwoofers 43 14th October 2009 04:39 PM
Center channel to compliment Mileva's EEatKSU Full Range 4 15th July 2009 04:36 PM
Sub amp/speaker to compliment S5 electronics K 12 G tube amp xxguitarist Tubes / Valves 0 22nd April 2009 02:57 AM
