cheap Subwoofer options
Hey all, new here and I have already purchased an A/V unit, 5.0 setup, and just needing a cheap temporary sub for right now. I live in apartments so just want something while in transition and then later will build something appropriate. I want to use an old ported box that I used in the car for a single 12" IDMAX. Its about 2.9 cubic feet and tuned to 32Hz from what the builder informed me. I also have a cheap 0.85 cubic foot sealed box that I bought from parts express a long while back for a 12" so either of those boxes are options for me although it doesnt appear the 0.85 box was built very well. I also have a SA240-B Dayton plate amplifier to use with whatever sub I get.
So my question is, what sub from say parts express would be recommended for either of those boxes with the kind of power available? I dont need the sub to play any higher than 60Hz. I would like to stay around $100, preferably lower but I can go a little higher as well. I said PE because I have a $10 off $75 coupon I can use if I purchase new.
One option I do have is I can pick up a Peerless XLS 12" for $80, but I dont think it would respond very well in either of those boxes. Any and all advice is appreciated and welcomed, I would like to get something here soon. Thanks!
Its about 2.9 cubic feet and tuned to 32Hz from what the builder informed me. I also have a SA240-B Dayton plate amplifier to use with whatever sub I get.
In that box and with that plate amp, without changing anything, the Peerless XLS 12" will give you 112db with an F3 of about 28Hz - all without any worry of cone over excursion - I'd say go for it !
Really? I dont have any clue how to figure out what size box will work with what sub. I tried to mess around with WinISD but still cant figure that out yet. But hey I guess I can go ahead and try it out, its just temporary anyway. Good to hear that it might just work out well 🙂
Actually since I already own and use a Peerless XLS 12", I already had all the parameters entered into my WinISD driver library so I just plunked in your enclosure volume and what you said it was tuned to, to get the results
Since you already own the SA240-B Dayton plate amplifier ( ie the one with some LF boost) I would suggest you add about 2db of boost @ 50Hz and it should give that configuration a fairly flat response from about 32Hz to 100Hz
Without knowing the size(diameter/length) of the port in that enclosure, the only thing to worry about is port airspeed - with that configuration using anything much less than a 4" diameter port will probably result in port "chuffing" on any content below 40Hz
OK, so it is a rectangular slot type port - given that sizing you won't have any issues with port airspeed.
BTW - the combination of the XLS driver, box volume and port size ends up with the combo tuned to about 26Hz - this now gives you a F3 of about 24Hz without driver over excursion issues using the Dayton amp and about 112db from 28Hz to 160Hz - you should still add about 3db of boost @ 45Hz to help even out the response curve
All in all it looks like a really decent combination
I'm not sure if adding any gain around 40-50Hz is a good idea - driver excursion one octave above tuning is twice the excursion at port tuning. Adding 3dB there requires yet more excursion......
It would be goot to experiment, but I expect room gain would fill in the EBS-style dip.
After messing on winISD, excursion won't be a problem until you're pushing it...
