Over the winter I'm thinking about experimenting with some spare drivers (Peerless 830500, aka XLS12) and PR's I have and experimenting with a 4th order BP using a PR instead of ports.
Does any current software allow one to model a 4th order BP with PR? If it runs natively in OSX then that would be incredible, though I know of no modeling software at all that runs natively on Macs. I do have Parallels with WinXP Pro so I can run my Mac in cripple mode and use non-OSX software if I must. Alternately, mathematically how could one "convert" a PR of known Fs, Q, Vas, and Mms to a "port dimension" that one could plug into Unibox, etc? |
#2 | |
Unibox does PR's, just not in the bandpass section. Since it plots the PR component response, you can model using unibox. Model a sealed box the same size (Vb) as the sealed chamber you will use with your bandpass box. Make a new driver - enter the resonant frequency and Qtc, (Qec and Qmc will increase by the same ratio) from the sealed box results and use a modified Vas that is Vac = Vb*Vas/(Vb+Vas) Now model this new driver in a PR box the same size as the vented portion of your bandpass and look at the graphs for just the port/PR response. If I didn't explain it well enough, I can model it for you and post a graph (my spreadsheet does PR's) if you come to a decision on a woofer and PR /box size combination.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley |
#3 |
Thanks, Ron. I'm going to try that out both ways and get back to you.
#4 |
I expect that LspCAD will be able to simulate this in more detail, also taking the parameters of the PR into consideration.
http://www.ijdata.com/ |
#5 |
Nothing against LspCAD, I'm sure it is a good program. Unibox takes the PR into account, and this method works. A 4th order bandpass is just a vented box with no contribution from the woofer, which is why you look at the port or PR only response. The sealed chamber modifies the parameters of the driver with increased stiffness.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley Last edited by Ron E; 7th December 2009 at 10:45 AM. |
#6 | |
| 4th Order Bandpass Help | berserker | Subwoofers | 9 | 19th January 2007 03:56 PM |
| 4th order bandpass 4 way | the phantom | Multi-Way | 3 | 27th July 2005 06:28 AM |
| simulation software - bandpass 6th order | fjmi | Subwoofers | 19 | 11th March 2005 07:28 AM |
| 4th order Bandpass- Effects of extending port outside of enclosure? | treedog | Subwoofers | 7 | 17th January 2005 06:27 PM |
| 6th-order Bandpass | BAM | Subwoofers | 1 | 24th September 2001 05:51 PM |
