Old 14th March 2010, 04:13 PM   #21
GM is offline GM  United States
GM's Avatar
Originally Posted by Brett View Post
Ported isn't quite as easy. 30L models a really nice box, but the get a low enough port air speed, the port becomes very long. This is why PR's are suggested.
Ergo morphing the box, vent into a reverse tapered TL (TQWT) seems a good acoustic solution to an acoustic problem.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 14th March 2010, 06:20 PM   #22
oodi is offline oodi  Canada
What would be the advantages of it over a sealed enclosure?
Old 14th March 2010, 07:25 PM   #23
GM's Avatar
More gain BW beginning below the driver's mass corner (~2*Fs/Qts) down to Fp where it will unload same as vented, but how much more will be dependent on the XO point/slope due the pipe's HF 'ripple' if not well damped. Of course if there's enough room gain to offset the vented alignment's unloading, then it's moot, otherwise some form of EQ may be required to protect the driver against excessive excursion.
GM
Old 15th March 2010, 03:02 AM   #24
tb46 is offline tb46  United States
Default Trio 8 in TH-SPUD
In the collaborative tapped horn thread aceinc started with the Trio 8s in a SPUD (Post #2816). This driver models well in a tapped horn, if you have the room, and if the limited frequency response is what you are looking for.
Aceinc added a lot of information in the Home Theater Shack.
(Tapped Horn Build TH-SPUD - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com).
Oliver
Old 15th March 2010, 05:52 PM   #25
Brett's Avatar
GM
How big physically would a TL like that be?
Old 16th March 2010, 03:32 AM   #26
GM's Avatar
About the same as your 30 L alignment plus a low mach vent plus the wood to fold it up inside the cab = ~48 L:
GM
Old 16th March 2010, 03:45 AM   #27
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
Hi Greg
Your size is pretty darned close to the unhorn!
Mark
Mark
Old 16th March 2010, 04:01 AM   #28
GM's Avatar
Greets!
If you say so, I never got around to reverse engineering it.
GM
Old 16th March 2010, 01:33 PM   #29
Default Tqwt
Hi GM,
The Hornresp impulse response for the TQWT in Post #26 looks a bit erratic. I wonder what kind of a sonic signature would result from that?
Oliver
Old 16th March 2010, 02:12 PM   #30
I some how think you don't need to reverse engineer it. The design is not all that tough and I know your no slouch at figuring out horn designs. Your tapered pipe idea is pretty close to the same concept. Most optimal designs for drivers end up being quite close to the same size box when Fs and efficiency are taken as baselines. We end up dealing with the same motor structures and moving mass. The only real different systems are front loaded horns that truly push the efficiency levels up. But that's at the expense of box complexity and of a lot bigger box to.
Mark
Mark
CSS Trio8 music subwoofer implementation? Brisso57 Subwoofers 21 25th November 2009 11:07 PM
Altair Sub (2x TRIO8's) Bigun Subwoofers 14 22nd March 2009 05:31 AM
Copyright ©1999-2013 diyAudio
