2 Drivers to enhance low freequencies?
Old 23rd November 2009, 04:17 PM   #1
jjohnston is offline jjohnston  United States
Default 2 Drivers to enhance low freequencies?
I have a question about multiple drivers and producing low freequencies.
Lets say I have 1 Driver that has an effective range of 60hz - 300hz. at 60hz it plays -3db. If I took a 2nd driver of the same type and set a 2nd order low pass filter at 50 hz its natural roll off would be -3db at around 60hz. So if I allowed driver 1 to just play with no hpf on it, and add a 2nd driver with a lpf of 50hz would that allow the sound to go down to around 40hz at -3db? Or would it not work that well?
Old 23rd November 2009, 04:37 PM   #2
badman is offline badman  United States
badman's Avatar
Pretty common approach but you have to be careful with 2nd order filter- make sure you don't wind up cancelling rather than reinforcing
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 23rd November 2009, 04:39 PM   #3
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Why not use a dedicated subwoofer instead of the same midbass that's covering 60-300?
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 23rd November 2009, 04:50 PM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
The same driver again is a .5 way system, where a 2-way speaker, with an extra mid/bass added, XO somewhere low to help with bass would be a 2.5 way system.
Go for it - you'll learn more from your own experience than from us telling you.
My work: www.grimshawaudio.com
Old 23rd November 2009, 09:13 PM   #5
The reason I want to go this rout is for space, and making it all look hidden. I think I will just try it and see. I really am curious about learning how to get it all to work. Is there anything I should keep in mind when looking at the 2nd order x-over to avoid frequency cancellation?
Also, if I take 2 full range speakers (L & R) can I take the outputs from the LPF of both, and play both into the 1 bass speaker, or would I need some diods to keep the 2 outputs from conflicting?
I'm designing to build a very small sound bar. Thats why its all small stuff.
Old 23rd November 2009, 09:47 PM   #6
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Only things that occurs to my mind are the terms "Isobaric" and "2nd Harmonic distortion reduction"
Bye
Old 23rd November 2009, 10:09 PM   #7
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
If you are connecting it passive no it won't get you any more extension.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 24th November 2009, 12:24 AM   #8
OH, so it would need a seperate amp not setup as a x-over on the same channel?
Old 24th November 2009, 11:01 AM   #9
Did it Himself
It will need more signal than the other driver in order to achieve any extension, the only real way of doing this is to power it by another amp.
Old 24th November 2009, 12:43 PM   #10
Glowbug's Avatar
You're running up against Hoffman's Iron Law here. Small enclosure size, efficiency, low frequency extension. Pick two
Jim
2 Drivers to enhance low freequencies?Hide this!Advertise here!
Music 'can enhance wine taste' ssmith Music 9 16th May 2008 11:12 PM
modifiyng to enhance sound zullo Multi-Way 4 7th February 2004 08:05 PM
