I have a very tight space, I don't need to rattle the room, but I want the nice low end rumble to be audible down to around 40 or 50 hz. I found some peerless speakers that say the freequency response is 20-5000 hz. But the Fs on them is 77hz. Would those work for reproducing low end freequencies down to like 40 hz?? the Fs worries me. I could set a x-over below that point if it helps...
#2 |
8'' High Excursion Woofer | MCM Audio Select | 55-2421 (552421)
NHT drivers and electronics surplus sale Not knowing your ambitions on this..... here's a simple and cheap option. Make a sealed box of about whatever dimensions you have available to you around 1 cubic foot and stuff it with polyfill. (I would personally not down fire this sub, but instead side or front fire) The spectral tilt on the jack hidley amp will flatten response. Put it in a corner with the driver facing toward one of the walls, angle slightly out into the room. Should be good and on the cheap for a small space. Jack has good info on how to mod that amp if you need to tune it to your space. Last edited by jbell; 18th November 2009 at 04:12 PM. |
#3 |
I just built a sealed box 21x21x21cm using Tangband W6-1139. Need some 6dB bass boost to get it down to 25Hz, but for my small study (16 sq m) more than enough.
I think you can find enoug info on the inet for the TB. Patrick |
#4 |
Do a search for "ripole". An unusually compact bass loading configuration that lowers the Fs of your drivers!
#5 |
If you want really small, and have some budget, it is hard to beat a CSS SDX7 (with minimal mods) in a sealed box. I am currently enjoying a single in a 12" cube (we also stuffed a Foster/NHT plate amp into the box).
This driver will work in a box between 3.5 & 21 liters (i'd suggest 7 litre min), we usually target 14 or a bit bigger. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
I've got an sdx7 and it's amazing! I was just now doing a/b comparisons w/ one of those in a 10" cube I built )w/ a foster plate amp on the back), with a 12" boston acoustics I purchased.
There's almost no difference in tone. the 12" does go a little lower.. The rumbly decay on some low bass plucks stands out just a hair more, but overall the tiny sdx sounds better. And for only 6.5", it's truly amazing. I should add that they cost about the same, even with the super inexpensive foster plate amp in the one I built. And that does NOT include my labor in building the little sub. It has me wanting to build a big sub w/ an sdx15 or something.. maybe some day... Last edited by wicked1; 18th November 2009 at 07:59 PM. |
| Compact budget subwoofer: vented or TL/Horn? | mvangel | Subwoofers | 21 | 5th February 2009 12:21 PM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 04:19 PM |
| Compact subwoofer | Vatos | Subwoofers | 0 | 20th March 2003 09:17 AM |
| Page generated in 0.08140 seconds (77.45% PHP - 22.55% MySQL) with 10 queries |
