Old 16th November 2009, 06:44 PM   #1
Default Budget subwooofer system
Hey, i'm currently in the middle of constructing a pair of Microbes for a friend of mine, and i'm going to need a sub to add some lower extension. I am aiming to spend around 200$ for the driver and amp, we will build the box ourselves out of MDF.
the sub does not need to be incredible, this is an upgrade from a set of ipod speakers however I am still aiming for some quality. I recently repaired an old sub with a 40$ partsexpress driver and 70w dayton amp and something along those lines would suffice. However that build was a compromise just to get something working so I am willing to spend a bit extra here if necessary.
does anybody have some suggestions for a sealed sub to use in a smaller size room?
Old 16th November 2009, 07:39 PM   #2
gooki is offline gooki  New Zealand
Madisound have the Peerless XLS12 and XXLS10 on special at the moment.
In a sealed box you should get more than adequate performance, and if budget permits down the line you can add a passive radiator or a high output amp with EQ to extend the low end.
Old 16th November 2009, 08:55 PM   #3
jbell is offline jbell  United States
NHT drivers and electronics surplus sale
ASW-1203 Car Subwoofer
Amp from Jack, driver from Dr. HSU.
Although I would personally put the driver in a 25hz ported cabinet.
Old 17th November 2009, 08:51 PM   #4
The ASW-1203 is no longer available.
Budget T-amp system sub? wakibaki Subwoofers 21 3rd March 2008 02:30 PM
Budget system / Realistic Nova-10's truz05 Multi-Way 14 16th January 2007 11:04 PM
budget dorm system Evazan Multi-Way 10 22nd September 2006 05:18 AM
budget sub-sat system with tangband drivers DIY_Peter Multi-Way 1 11th December 2004 06:20 PM
Budget for Surround System? CZ Eddie Multi-Way 4 23rd November 2003 10:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
