Odd shape box design help needed...
Old 16th November 2009, 02:56 PM   #1
bobduch is offline bobduch  United States
Default Odd shape box design help needed...
Friend of mine got a new 12" sub for his car (I know this is not auto section,please bear with me) and needs a 2 cf sealed box. He has in place a 1.5cf sealed box. Current box is almost rectangular in shape but does not have parallel side walls. Nice.
So here is my question. He does not have room for a bigger box but could add an irregular shape to the existing box or run a connector to where has has room for a .5cf box. Could he run a tube from the 1.5cf box to another box of .5cf? Or something like that. If so how small in diameter/how long could the tube be? (Tube would obviously be reinforced.) Could he theoretically add a long 4" of 5" diameter tube until he had the extra .5cf? In other words, the air in the sealed box acts as spring. What are the limitations to the shape of the spring?
Thanks,
Bob
Old 17th November 2009, 03:37 AM   #2
PeteMcK is offline PeteMcK
The best bet is to put the driver parameters (if available) into WINISD and see how much difference the change in box size will make. You'll probably find that there will only be a small difference in the LF roll off, & you'll be able to use the existing box ...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 17th November 2009, 03:10 PM   #3
Or just play with fill. I know.
But now I'm curious and want to know the answers to my questions.
Old 22nd November 2009, 06:25 PM   #4
Suricat is offline Suricat  Canada
bobduch, I am afraid that creating two chambers connected by a restrictive link will do just this: creating two chambers. You will not be able to directly add the 2 volumes and will err in unknown territories. Unless the link resistance to air movement is neglectable, for example, when adding braces around the inside of a box.
You friend is better off doing a composite panel that will adapt to the car's shape. But before anything, go with PeteMcK advice and simulate in WinISD. You might be very surprised. In anycase, you will raise the total quality factor of the box-speaker assembly (Qt). Who knows, that may be exactly the bass increase you like in your car!
Good luck,
Suricat
Odd shape box design help needed...Hide this!Advertise here!
Design Needed Bluto Subwoofers 9 8th November 2007 06:24 PM
design help needed. neazoi Tubes / Valves 14 8th September 2007 04:43 PM
Sub design assistance needed mwb Car Audio 10 7th November 2006 04:55 AM
Design tools needed augerpro Multi-Way 8 16th September 2006 01:48 AM
PCB and Design needed prozach7 Chip Amps 0 15th August 2006 07:25 PM
